Just got my hands on one of the new XSPC Dual DDC Reservoirs and test fitted it in a Coolermaster ATCs 840
No doubt, its a quality bit of kit and comes complete with both black and silver face plates so should fit in with most standard brushed aluminium cases and for those wanting to mod there own face plate like myself it will be an easy mod to design and cut your own bezel.
Was a tight squeeze to get it into the 840 but once its in, the black brushed alu face plate matches the case perfectly and looks stunning imo and i think many would be more than happy with how it looks right out the box.
Nothing on the XSPC web site to suggest what fluid can and can't be used but i've used Feser in many of their other similar reservoirs without any problem so would imagine this would be the same.
Anyway, i thought id get a few pictures up installed in the chassis and also add some blue and red dye to show the potential of the dual loop.
No doubt there will be testing done soon from those that can but just thought i'd add a few pictures.......
http://www.coolercases.co.uk/xspc/xspc_res_1.jpg
http://www.coolercases.co.uk/xspc/xspc_res_2.jpg
http://www.coolercases.co.uk/xspc/xspc_res_3.jpg
http://www.coolercases.co.uk/xspc/xspc_res_4.jpg
http://www.coolercases.co.uk/xspc/xspc_res_5.jpg
http://www.coolercases.co.uk/xspc/xspc_res_6.jpg
http://www.coolercases.co.uk/xspc/xspc_res_9.jpg
http://www.coolercases.co.uk/xspc/xspc_res_7.jpg
http://www.coolercases.co.uk/xspc/xspc_res_8.jpg
