MA790X / MA790XT-UD4P 790X bugs fixes etc etc.....
Guys if you have this board post here.....I will see what I can do, maybe i can get a board.....we'll see.....
Someone break out the camera, mobo thread is not official without board pics...
Bugs issues etc etc.......
This is not the place to complain about your 720 not hitting high jigahertz.......it's most likely a chip related issue........and not a bug...its a 720 for a reason....
Voltages not applying such as NB vid with Hybrid ACC enabled which has been brought to my attention would be considered a bug.......
UPDATE THE X4_550Beast lives...time to play UD4P..goodness
First off i set Defaults and unloaded the 720 andInstalled 550BE.
1st BOOT In Hybrid Mode,, F5A Bios UNLOCKED .
Next :
Noticed is Vcore is 1.35v Default.
Then:
NBvid is @ 1.1vid Default... This is lower than my 720 @1.2vid
Now :
Im getting and Idea where the Temps are and will slowly bump up the Volts to see how the Heat rises.
Interesting :
It may be a 955 variant. Its temps are 26c Idle Bios @ 3.1ghz X4cores and 1.34volts .
The 720 was 28c Idles@ stock 2.8ghz X4cores 1.3volts.
It could be the default NBvid too. Only way ill know is to raise it up some:yepp:
Last serial 90020........Step is 0921 APAW:D
http://i168.photobucket.com/albums/u...4P_F5Abios.jpg
Will post clocks later,, Im seeing what volts this thing likes and if the NB goes higher than the 720 @ stock NBvid volts.
