DFI 790FX-M2R +955 worky just fine ;-)
Been playing: http://www.ocztechnologyforum.com/fo...d=1#post381860
Got some new Blade LV1066 to test also...
Not got anything newer from DFi so thought I would have a go and see what I could get from the old girl, fact is its pretty awesome for a simple CPU upgrade.
Issues i found.
VID over 1.45V would cause BSOD...maybe my CPU
ram clocking is different with 955 and this beta bios, old modules doing 1066 easy before now do not...but I tyweaked at 800 to be just as fast.
temps are way off, no way does this CPu idle at 17C LOL
http://www.ocztechnologyforum.com/fo...1&d=1241186063
It gets better...MUCH better
Low voltage challenge...3.6GHZ and 1066ram
