Simple poll.
Comments welcome. :)
Simple poll.
Wasn't it just you that asked this >?
For me I like the Koolance all the way!
i will release a review soon. comparison between EK, Koolance and this beauty :)
http://www.abload.de/img/img_7074osgw.jpg
http://www.abload.de/img/img_7078vrjj.jpg
http://www.abload.de/img/img_7083zplf.jpg
http://www.abload.de/img/img_7097lu78.jpg
http://www.abload.de/img/img_7108czjs.jpg
http://www.abload.de/img/img_7121oqj1.jpg
...stay tuned !
Dynamic Duo :D
http://www.abload.de/img/img_7218ldny.jpg
Is the heatkiller block available in the US anywhere?
performance-pcs.com listed a bunch of watercool products in the last days, maybe this block is available there too ?!
http://www.performance-pcs.com/catal...order=6&page=4
http://www.abload.de/img/img_71288d3r.jpg
http://www.abload.de/img/img_7130oljo.jpg
http://www.abload.de/img/img_7135nfkx.jpg
http://www.abload.de/img/img_7139viwr.jpg
http://www.abload.de/img/img_714185lh.jpg
http://www.abload.de/img/img_7143p6pd.jpg
http://www.abload.de/img/img_7191uap2.jpg
http://www.abload.de/img/img_71980aaa.jpg
http://www.abload.de/img/img_7202d8jp.jpg
u guys forgot out of all the blocks shown,
Koolance is the only one with real working standoff's
so its a no brainer in which block to pick.
Bundy you need standoff's on your blocks, or a lot of people on this forum WONT buy them.
We went though nightmares with the EK blocks not having standoff's, so a lot of people arent gonna repeat that mistake. Eddie even made revisions with standoff's but unfortunately, there not perfect and still giving a lot of people problems.
^ +1 basically what are standoffs?
I made a hugh deal about this and forced Eddie to make them on the revisions basically.
However, he hasnt gotten them done correctly yet, a lot of members are still reporting they have no clue on how to get the standoff's done correctly on the EK blocks.
The Heatkiller block has no standoff's so it automatically gets thrown out the door on my recomendations:
http://www.xtremesystems.org/forums/...93#post3365293
im sorry it looks nice but whats a point in a block that can damage your card by warping it?
Standoff's in silver:
http://www.koolance.com/water-coolin...d-nx295_p1.jpg
Standoff's machined directly onto the block:
http://www.dangerden.com/store/image...?1237409098556
See KL and DD is the only 2 blocks right now with standoff's. So those are my only 2 recomendations when it comes to fullcover blocks.
I think the majority of the problems comes from peoples incompetence in installing. I have been using ek full cover blocks since they started, and have yet to have a problem. Great temps, great contact.
Don't the EKs come with plastic standoffs?
at first i thought that too.
til i started warping my cards, and then Cyberdruid shorted his cards, and then theres countless threads of people who shorted or warp there cards.
So unless your calling me and cyberdruid and a few other vets incompetient in fc installing, no... FC cards without standoffs are just flawed in general.
They do, but they give people like shazza and seeker issues in getting them setup correct, and i call that a failed standoff as well.
careful note when installing a FC card on a dualcard gpu like that.
the internal mini sli cable is not backwards compatiable. Meaning theres only 1 way it can go in, but fits 2 ways.
A lot of people goof on this part, and it makes the card not boot up. So make sure you pay extra attention to that internal SLI cable.
When you pull the stock sink you'll know what im talking about.
good call on the standoffs, it was like it was a big issue then everyone forgot, i was watching this thread to see
if the person reviewing them and obviously a fan of the HK's was going to mention that issue.
myself I am a big koolance fan
A touch of glue on each plastic standoff to hold it in place over the hole should be enough on the EK, though I agree Eddy should be milling them right into the blocks. Especially for what he charges!
Thanks.
I'll try and keep the SLI cable intact if I can. FFCs like are a nightmare to work with.
wow i forgot all about those days, using mcw60's and maze 4's and gluing all those heatsinks, man those were the days, i kinda forgot till you mentioned , guess i'm spoiled now that i am using full card blocks.
i remember last year when i got a ek 9800gx2 block, i screwed it down and i wasn't paying attention and when i went to check it before i used i i noticed the card was out of wak, luckly i didn't mess it up, but that is when i first noticed the standoff situation, i used some spare rubber washers that i had around.
Having looked at both the ek and koolance blocks, the koolance was cheaper and just seemed to be the better design. All 3 of my 285 koolance blocks went on with ZERO issues and i'm getting great temps.
I also went with the Koolance blocks for my 295s.
I've used Koolance fc blocks for my last three card generations and were great and keep getting better.
Ah ok so standoffs are the bits that cover the other ram bits on the card?
I believe some had problems, because of tightening the screws too much, until the bent PCB touched the block.
I believe we have to take this into our account so even the most unexperienced users can mount it easily.
So EK has started implementing standoffs into the products. Starting with 4870 GS and continuing with Acetal standoffs at 295/285/260(55nm) that can be used or not, depending to the user wishes. But I can say the experienced user can mount the block without standoff with better result.
This is the picture how the standoffs work:
http://ekwaterblocks.com/shop/images...stand-offs.jpg
older post I know put the question fits.
I recently installed my BFG-GTX295 on the Koolance VID-NX295. I'm using the thinner thermal pads as of now but I may have to change to the thicker pads because I'm getting a warp/bowing on both cards.
Has anyone had that problem with the BFG 295? I', thinking if I change out the thermal pads to the thicker ones I may not get the block/GPU contact as good as using the thinner pads?
Any recommendations, say maybe unscrewing the stand offs a bit?
Thanks, Quels
