Sapphire ATI HD 3870 ALL YOU NEED TO KNOW (OC'ing)!!!
I've spent the last 72 hours with barely any sleep figuring out how to overclock this puppy properly, and with high stability. First, here are my recommended requirements:
POWER: at least 520w with at least 30amps on the +12v for single cards. CF required at least 38amps. Single rail PSU's always overclock better.
WARNING!! REMOVING THE STOCK HEATSINK VOIDS WARRANTY! SO DOES FLASHING THE BIOS! Do so at own risk...
COOLING: If you want lower temps, re paste the core with AS5. Leave the gummy thermal pads on the RAM sinks and the PCB. Force GPU fan to AT LEAST 70% via RivaTuner (will get to that later in this post). And the most important part, room temperature and case/air flow! That is crucial! I have the antec nine hundred case + window is open + Canadian winter temps and in the summer, air conditioning is on 24/7.
FLASHING BIOS: Don't use any of the voltage modded bios's. They don't work.
Flash Bios to the updated version released by ATI (HD3870_PLLVCO_v010.071). Use ATI Flash 3.49
SOFTWARE: Remove any old drivers using Driver Cleaner Pro. Best results are to use driver cleaner pro in safe mode. Clean all ATI.
Make sure you have the latest version of DirectX installed (November release 2007).
Install catalyst 7.11, then reboot.
Install RivaTuner 2.06 and adjust fan speeds to FORCE at LEAST 70%.
Install GPU-Z.
OC'ing:
I've tried using Catalyst overdrive, and the auto tuning. Both have failed. Low -level overclocking seems to be the most stable method for now via RivaTuner.
CORE: Using RivaTuner, Set the core to 877mhz. Only 13.5mhz increments work on the core. Default core frequency is 777mhz. (13.5x65=877) If you set the core to 877mhz and GPU-Z reads 864, set the core to 878mhz, then GPU-Z will read the core as 877mhz. Try setting 877mhz first.
MEM: This is the tricky part.
The Ram Chips are labeled "Samsung K4U52324QE-BC08". The default frequency is 1126 however, These modules are rated 1250mhz and usually, you can push close to 100mhz OC on the GFX mem with stock cooler, and equivalent or a little more than 100mhz with proper airflow/cooling.
I'm not sure what increments the mem uses yet, So use GPU-Z to match the clocks (Set your mem clock to whatever in rivatuner, then check GPU-Z to see if they match. If they don't, set the frequency displayed in GPU-Z in rivatuner).
My mem is currently clocked at 1304mhz, so try that.
Keep an eye on temps. My idle temps varry 45-48 and my load varry 54-58.
PCI-E Frequency: Depends on your chipset and motherboard. If you're using SATA drives, don't go over 120mhz. Mine is set to 110mhz. I do NOT recommend 120mhz if you have an older motherboard chipset.
Good luck! Post Results! :up:
UPDATE 11/29/07: GPU clock 877 unstable on latest games possibly due to lack of voltage. Use 864 for Core.
UPDATE: 12/08/07: Use 864 for core with ATI's initial bios relase, but if you use sapphire's bios relase, 877 seems stable.
The mem is rated 1250mhz at 0.8ms latency at default.
1 Attachment(s)
Thanks for the poll results guys!
Thanks for the poll results everyone, I'm glad that I could help all you 3870 owners.
Just to draw attention, volt mods are out. I've heard of people achieving 1gig clocks on the GPU. Given some time I shall attempt this mod and keep everybody posted.
In the mean time, here are my final results of 3dmark06 full tests repeated 3 times.
Samsung chips rated default: 1250mhz
I found out from a review that these samsung chips run at default 1250mhz at 0.8ms latency.
I've been experimenting with 27mhz incriments and I have found the card to be extremely stable at 877/1304.
Remember, 3dmark06 does not test full stability since you are not using any of your input controls (keyboard, mouse). it is more of a test for stability of viewing graphics rather than controlling them.
I am confident that with proper ram and pcb cooling, and increasing the latency should allow a higher clock on the memory.
But with that thermal goop being more of an insulator, don't expect the memory to gain that much performance when oc'ing.
The core is where the performance is at. Hardware volt that thing, and the card will be flying!:up:
Not much performance boost.
Originally Posted by
laragirl83
PCI-E Frequency 110MHz...
Its been around in my mind for a while, but still, someone get this clear to me!
PCI-E freq. default is 100MHz right? in some case, lowering or give a little more helps to avoid mobo bugs, like p5b mobos, when pci-e speed drops to 1x instead of 16x.. bit still, does it give any real performance boost if I set it to 110 rather than 100...?
Raising the PCI-E frequency helps stabilize high OC clocks.
It really does not provide a performance increase.
Setting the PCI-E too high might get you more clicks, but may cause instability..and if you use a 965 chipset, you can corrupt your SATA drives and loose all your data.
