Gigabyte GA-N680SLI-DQ6 Testing
Good feedback on this new mobo, but you didn't say what CPU cooler you have used. Do you think Zalaman 9700 or Big Typhoon can be fitted on the mobo?
Thanks, and keep posting your findings.
Using XP 32 Pro SP2...fully updated
As strange as it sounds I am going to pull the sli bridge and see if enabling it still does the same thing...without the bridge...I checked the resources on the cards and they are IRQ21 and 22....
Pulling the SLI bridge made no difference. Sam thing...crash crash crash
Zalman 9700 NT CPU Cooler
revenant,
Some customers on newegg say that they couldn't install this fan on the board. Have you needed any special work to install this cooler?
FMT
