Seems to be stable here.... :toast:
http://img144.imageshack.us/img144/4970/clip2yd8.th.jpg
Damn nice oc with those load temps! What is your ambient? Makes me want to go water.
My CPU is naked on water...:DQuote:
Originally Posted by Peter949
Also PWMIC is cooled by a Fan on them and Ambient temp is about 28C right now...;)
good job man! freaking sweet OC on 1.512v,. might want to post a OCDB entry on dfi-street ;)Quote:
Originally Posted by Dagalidis
I have an DFI Lanparty NF4 ultra-d and a Opty 165..what is the best BIOS for this config?
Thanks a lot :)
This depends on your memory.Quote:
Originally Posted by lupacchiotto
Dagalidis that is a godlike chip you have there. :woot:
Hi,
Anyone familiar with these Dual AM2 Opterons?
AMD Opteron 1210 Santa Ana 1.8GHz Socket AM2 Dual Core Processor Model OSA1210CSBOX - Retail
64 bit Support: Yes
HT: 1000MHz
Hyper-Transport Support: Yes
L1 Cache: 128KB+128KB
L2 Cache: 2 x 1MB
Multi-Core: Dual-Core
Process Type: 90 nm
Series: Opteron
Virtualization Technology Support: Yes
Vista Ready: Yes
AMD Opteron 1212 Santa Ana 2.0GHz Socket AM2 Dual Core Processor Model OSA1212CSBOX - Retail
64 bit Support: Yes
HT: 1000MHz
L2 Cache: 2 x 1MB
Process Type: 90 nm
Series: Opteron
Vista Ready: Yes
I have my Opteron settings http://home.no/erikkjos/optyclock.htmQuote:
I will try to post my memory settings soon.
What is the best BIOS for DFI Ultra-D + Opteron 165 + G. Skill 2GB HZ ? My computer is starting to act crazy lately so i removed OC for now..
dude... find out for yourself.Quote:
Originally Posted by ahmadmz
yeah, what about them? the 4000+'s i sold were the exact same processors as the 1210's and ALL of them hit 3ghz easy.Quote:
Originally Posted by Billy_BAD_Boy
dave
Have had a CCBWE 0601 running a week now.Its a bit difficult to get good steppings in the uk.Running at default speeds but stable on 1.225v.
Smiffy
my opty runs great!! ccbbe
this fourm has soooo died after the conroes came out
well i got a water chiller on the way so ill beable to join the 3 gig club im at 2900 but 3000 runs too hot or i have to run my ac at 68 deg F
ill be playing with my opty with the chiller till kentsfield comes out or amd takes back the lead and that could be a long time
________
Bullitt
My current 24/7 speed :) Problems have been solved, although it still reports funny.
http://valid.x86-secret.com/show_oc?id=123849
http://valid.x86-secret.com/ccpuz.php?id=123849
-Satan
guess your not a gamer using "2x512mb G.Skill Extreme Series GBFF DDR600" ?Quote:
Originally Posted by LordofDoom
single gig of ram to show off benchies or everyday use?need 2 min,i run 4 gigs cause running hi res 1800x1440 on 7950,bf2!!
Hi All
Got it wrong,running at 1.20v.Gonna see what it does on Nautilus 500 then gonna shove it under my Prommy GTll.
Smiffy
Railmeat, I did not understand that post at all. From what I hope I understood, yes I am quite a gamer and F.E.A.R. and CS:S run fine at max settings at 1680x1050 on my 500/1500 7900gt.
-Satan
I have been working with the 3200dr for a few months and i have seen all the bios,cold boot, uli issues.
I think i have found the fix for all of them at once.
I now think all three of thoses issues are caused by the same core problem.
this is what i did
downloaded newest bios 7/28/06 I used newest winflash to flash it from within windows winflash 1.83
before i flashed i shut down the pc, took out all my memory, put 1 stick in the far yellow slot, powered on the pc and went into the bios.
then i held down the two motherboard buttons at once and it cleared the cmos.
booted back to the bios and configed all my voltages and stock settings
200 fsb ect
then booted to windows and flashed the bios
rebooted
cleared cmos again
ok done
powered off pc and reinstall the ddr to both orange slot
i run 2x512 corsair pc3200 xl xms v 1.2 brain power @
500 @ 3.2 v 8 3 3 2.0 1t
overclocked the system from 2.0 ghz to 2700 ddr to 500
no cold post hangs, no sata issues , no pauses and no event notices
i gained few hundred meg of memory bandwidth
7800 read 7700 write @ 34.1 ns in everest
and that write speed kills conroe cpu+chipset motherboards with corsair ddr-2 memory
look at that and think about it the benchmarks
the conroe gets a little higher read but the write is compable to this plat form with cpc @ 2t
so the moral of the story is
the 3200-dr has a ddr detection issue and misconfigures something that i have no controll over changing.
but only after a flash
so only flash with 1 stick in a yellow slot
that has resolved all motherboard issues on 3 cfx3200-dr boards
and i have confirmed
and yes my other 2 buddies baut the beers
ahahahahaha
Ok ill find out myself.. u also dont ask anything in the forums.. find out ur self ..Quote:
please try not to say anything if your not going to say something nice or be helpfull...Quote:
ahmadmz: try googling "opteron 165 dfi expert g.skill hz" (replace with your specific parts... but dont get too specific) should bring up a whole stack load of hits for people's sig's on forums.. check which bios they have and try them...
prob a good place to start is dfi-street... i believe tony over there mod's a few bioses to resolve niggly issues..
mjs1231: Nice work, a mate has this board which we're setting up for him next weekend... will save us some headaches :D
amazing price drop for dual core opteron s939 :slobber:
AMD Opteron 165 Dual-Core 1.8GHz 1MB (per core) 64/32-Bit Socket (939) (Retail Box-w-Fan)
Code: 120338
Price: $165.99
.Quote:
AMD Opteron 185 Dual-Core 2.6GHz 1MB (per core) 64/32-Bit (939) (OEM)
Code: 120305
Price: $360.00
http://www.monarchcomputer.com/Merch...de=AMDOP9391dc
Deal is dead.
edit.
Guess not.
how do you mean? just clicked the link and there was some more there.Quote:
though this prob means monarch/amd is trying to clean out the warehouses for The New Stuff (tm) :D
opteron 165 for 85 € http://v2.webdistrib.com/(7a6272826f..._p_304331.html
:woot:
I receive mine maybe saturday.
more screens soon :toast:
