Hey Napalm
I also used hight vtt to achieve 4860 to shoot some SPI, can you post a template of some of your high OC's so to try...if its not problem for you of course
Thank you
Cheers :up:
Sergio
template?? this whole thread is plastered with my results/voltages
4.6ghz @ extreme: 1.62vcore/1.64vpll/1.66vtt/1.80vmch/2.66vdimm fsb:mem 4:5
4.8ghz @ dq6: 1.6vcore/1.6vpll/1.8vtt/1.8vmch/2.6vdimm fsb:mem 1:1
note: much higher load on the extreme than on the dq6
you guys are water/freezing water/phase/whatnot cooling and then youre telling me if i ever tried lower vtt :shakes:
for air cooling higher vtt is what keeps it going
then again i guess im just a retard maxing voltages for no reason :up:
I guess that means no template lol? I like seeing posts from people that push it to extreme for months or even years. It lets me know that these chips are a lot more durable than people think. Eventually Im sure they will degrade and die but if I can get a year or even 2 years out of it and enjoy seeing how far it can be pushed then I got my moneys worth. At least that's how I see it.
^ ud3: 1.7-1.8vpll applies ^
always:
CPU Clock Drive................................[ 1000mv ]
PCI Express Clock Drive......................[ 1000mv ]
CPU Clock Skew.................................[ 0ps ]
MCH Clock Skew.................................[ 0ps ]
as for ref voltages.. always @ default
Why would vtt make a bigger difference for air cooling rather than water cooling? I'm asking out of genuine intrigue as I can't understand the logic behind the statement. Thanks!
genuine indeed.. cause you/some of you since last year are still confused on what it takes to oc q9650
better cooling > lower voltages than air
you guys dont push your q9650 hard enough thats the issue
thats your problem not mine cant help there
well, even with a TRUE with 2*1800rpm fans, plus another 120mm blowing air towards it and another pulling it out of the case at the back, I'm still pushing my Q9650 to 80C or more. I don't think any more vtt would help the situation... I've seen the right side of 4.5GHz but I won't see it stable. It's 35C outside and about 26C in my room. Too hot to do battle...
yes napalm i pushed it till 4860 you can see it also on my posts, but i also prime and ibt and i really don't think you can prime on air at those voltages for 8 or 9 hours unless you live on the North Pole lol, even if you can i can't as my chip is 1,1875 vid wich is hell at half of those volts
thank you for your answers :up:
Sergio
Just because I use water now doesnt mean its always been on water, ive just seen the light. :up: You seem pretty defensive over what was a simple question.
Maybe thats part of your problem there, default ref. voltages and skews are for low clocks. :up:
Napalm this is dedicated to you Jor3LBR and OC nub, my first BOOT from BIOS at 535x9 = 4815 :up:
NOT using ET6
using auto timmings just to try
http://img232.imageshack.us/img232/4116/481510702.png
Cheers all :up:
Sergio
Nice Amigo :)
Can U Submit Some 3D Banch Testing? With That Frquenc 4800MHZ
I Sell DFI And Give UD3R Next Week
I Just Know This Frquency What Can Give CPU Score In 3D 06?
Tanx M8
Gracias amigo :)
That was my first boot at that frequency, will keep making in stable for bench and tweaking volts, as its a very low vid chip its hell at those volts but either way i will push it :yepp:
either way as an advance here's a ss for you at 4707 3DM06 also booted from bios
http://img411.imageshack.us/img411/8674/47073dm06.jpg
Cheers :up:
Sergio
thanks mate :toast: but dont have to dedicate to me
thats just 4.8 foreplay right there^ at such low voltages
set vtt to 1.7 max
set vmch to ~1.8
set vpll @ 1.74/1.8 whichever boots up
set vcore @ 1.55-1.575
set vdimm @ 2.5 trust me i got the same kit and runs ~2.7 on a daily basis :up:
ram timmings: set 5-5-5-15 and the rest of the timmings set to what the bios shows
try both 1:1 4:5
you havent seen what your setup can do yet mate.. give it hell and you shall reap new oc clocks :toast:
Nice job Sergio :up:. Very hard to boot above 530.
very hard to boot over 530 ??
2x q9650 545fsb windows booted + validation @ 4.9ghz on air.. no easytune
http://img515.imageshack.us/img515/5507/4905od4.jpg
http://valid.x86-secret.com/show_oc.php?id=422821
http://img158.imageshack.us/img158/4319/4905zr0.jpg
http://valid.x86-secret.com/show_oc.php?id=434280
1.2125vid: lower vcore @ higher temps
1.2500vid: higher vcore @ lower temps
both air cooled by the same ifx14
havent checked but i think its still the wr on air
dont worry mate im not attacking oc nub
just wanted to show that a good mobo/right voltages and settings.. high clocks can be booted even on air.. thats all
i just checked the q9650 wrs: http://www.ripping.org/database.php?cpuid=851
so mr. hoss331 here claims that his best clock 4958.98 is on air ??
http://valid.canardpc.com/show_oc.php?id=509199
lying lamearse bastard.. you water/freezing water cooling (you said it yourself) and then you claim "air" :shakes:
good luck with your bulls{}t
Managed to hit 4914mhz on the Q9650 today, can't boot close to that or run it stable close to that though...
I'm just running 1.62v CPU and 1.54v MCH.
1.8v on the MCH core? Seems like a lot, what cooling is your mobo on?Quote:
set vtt to 1.7 max
set vmch to ~1.8
every ep45 can run @ 1.8vmch air cooled
if it seems like a lot to you.. dont run/set it @ 1.8
you guys keep comparing ud3 vs my dq6/extreme while none of you got the same components i do.. not all ep45s are the same.. you guys went against everything (components/voltages) ive suggested.. dont expect the same results.. if one cant afford the same components i dont hold it against and never did
Are you kidding me, your getting worked up over nothing. :down: Calm down killer.
Maybe you didnt understand this well but it means, yes I currently use water now, but I DID NOT a few months ago. I switched over to water in mid MAY and if your so concerned about it I can probably find the receipts for you. That validation WAS done on air (S1283 w/FM123 fan) on February 16th, 3 months before I had any water parts. I havent even tried for a higher clock on the 9650 or 3380 for that matter since the water setup has been put on. Again, you need to calm down. :up:
Anyone know why I get a rejection from CPUZ? I submit a 4851mhz oc and get this email:
http://img245.imageshack.us/img245/7576/rejected.png
I cannot boot in w7-64 at these clocks so i use et6 to go up.
Ok so I boot up at normal 4500mhz, try and validate and get another reject. WTF am I doing wrong? Prime blend 10hrs 4500mhz but fail CPUZ lol?
CPU-Z 1.52 tried ?
