thats great news!so which one are you going to pick?if it was me i would go #3
I have seen that stuff on a couple of brand new boards. I'm not sure what is it but I don' think it's insulating spray or coolant residue, I think it's something during the manufacturing process. I could be wrong though of course.
That's good to hear, I hope whatever you choose is a solid board. You have certainly been stuffed around.
cryptik, its definitely something spilled,after closer inspection of the top side you can see this stuff leaked down through the gaps of the memory slots.
That's really bad. I've seen light residue before, but if it's leaked down through the ram slots your lucky the board didn't fry you gear.
How could they send you something like that? I would have though they would not even accept something in that condition back let alone send it out.
hi guys this is my result in testing max fsb on my mobo
http://valid.canardpc.com/show_oc.php?id=466061
setup:
cpu@phase ss 1.2hp
nb@liquid cooling ybris k5
here some photo of my rig
http://i527.photobucket.com/albums/c...h_IMG_2149.jpghttp://i527.photobucket.com/albums/c...h_IMG_2152.jpg
http://i527.photobucket.com/albums/c...h_IMG_2152.jpghttp://i527.photobucket.com/albums/c...h_IMG_2152.jpg
http://i527.photobucket.com/albums/c...h_IMG_2159.jpghttp://i527.photobucket.com/albums/c...h_IMG_2168.jpg
http://i527.photobucket.com/albums/c...h_IMG_2169.jpghttp://i527.photobucket.com/albums/c...h_IMG_2171.jpg
here more photo of my setup
I did not use SuperPi before on this rig.
I am getting thus each time at loop 5 - on stock settings and also on 21h P95 blend and 10 IBT stable.
Any body can tell me about this
http://images50.fotosik.pl/41/9e080f4378783940.jpg
didn't want to hijack but yeah keep a eye on it.. i thought it was suspisious as it sounded like the problems i was having with mine.. i have the older maximus and 3870 cards and for months i wondered why my board wasn't stable at any oc or even stock. first raid many hard drives later i put in a single without raid which allowed me to stay stable long enough to start testing things, then ram, then psu, after many days/ months of testing things i finally figured out that i was having vpu errors as the older drivers i was using wouldn't show vpu errors it would just bsod only gaming. the later drivers started showing the vpu errors and also the sound looped and i could see the errors instead of bsod.. i removed the card and borrowed a 8800gts from my bro to test and it wouldn't crash anymore. passed every test no problems at 3.6+ and played games without crashing.. i am still waiting on the ati drivers and or bios that will work with my 2 cards.. i have tried them all even modded ones, different power ram and oses.. still waiting for my fix. have to save up and get a different card to replace these 2 i guess.
do they use flux for soldering? could be dried up or burnt on flux..
@cryptik, i never even tried this board.after i opened it and saw that it was warped and clearly used, i just started making calls to asus to rectify the problem.
hi guys n gals.
my question isnt for the ocing on this board, i have an ample oc from 2.4 to 3.6 on my q6600(air) and am slowly working on the memory as we speak. my problem is sound, where do we get drivers, the ones asus provide say my hardware isnt supported by the software and ends the install, i tried creative but cant find the card and googling doesnt seem to get me anywhere, just wondering if anyone has the same problems and may know of a solution...thanks in advance
peace
fatman
I'm almost there guys! Unfortunally, an C1 stepping plus a fairly high VID isn't a very good combination...:mad::down:The fact I'm all on air doesn't help either :(
I'll get it stable, though! Wish me luck ^^:D
http://i723.photobucket.com/albums/w...az/bad_CPU.jpg
Guys I need help!
Can anyone give me a reason NOT to get the Striker II Formula?
I havent had a NForce chipset since my A8N SLI Deluxe/FX-60 and would like to give it a go, unless there are issues with the board otherwise I'm getting a Rampage.
Anyone know of issue wich would make this a no go???
Would either run a Q6700 or a E8400, both are collecting dust on my desk.
Is anyone else experiencing higher load Vcore than idle Vcore when Load Line Calibration is enabled? Or is this an specific issue with my board? :shrug:
Okay, I couldn't get my CPU stable at the previous Vcore, so I decided to up the Vcore one more notch :p: It looks like I've got a new 24/7 setup! I'll switch to Watercooling in a few days, to make sure my chip won't die anytime soon :rolleyes::D
:up::yepp::clap:
http://i723.photobucket.com/albums/w...o-az/notch.jpg
It is hyperPi and I cant run it in compatibility mode - it will not start at all. As admin did not help.
It is hyper PI I am affriad and option for sound is checked.
But basically if PI does not pass test the error message does not look like this?
Let it run for 12h Blend and for real stability 24h :) (and it still can be unstable in 3d)
So I run 4 instances of Super PI and they passed no problem - so It looks like HyperPI does not want to cooperate with my sys - which is kind of crap as it is lot of hassle to run 4 instances and set affinities for each.
3h of small FTT should be more then enough. Go for blend it will tell you is your vtt and vnb stable.
This is decryption of errors - which I can confirm is working for me like a charm.
1024 - increase VTT or vNB
896 or 448 - vNB
768, 512, 332 - VTT
Thanks, that sounds really helpfull to try and pin down any stability issues that might arrive when I try blend. Is it possible to tell when the ram is the link causing the problems, though? Or should I run memtest first? I'm pushing my ram quite a bit too, it's running at 1140mhz, at PL8 at stronger, with static read control enabled ;)
Anyway, here's the result of the small FFT test :yepp: I'm off to try the stability with some games, as I'm dieing to play now :D I'll run blend soon. I'll keep you guys updated.
http://i723.photobucket.com/albums/w...-az/stable.jpg
need help OCing my new rig (Q9550)
got an E0 Q9550 from ebuyer, and a maximus II formula, and watercooeld it.
under OCCT my max FSB i can get to pass is 467, but game crash within seconds....
these are my voltages:
http://i277.photobucket.com/albums/k...Capture-18.png
(btw temps under laod never go above 50 on any core)
