ElAguila check out this thread it has a program that measures your tcase temperature which is to do with how well the cpu casing is applied on your cpu.
The higher the tcase the higher the overclock.
SideEffect, What chips are on your crucial ballistix ?
Prime again during the night ... argh it's too slow to testing the stability :(
That is an interesting thread. I ran the program and my max tcase was 63C. I was paranoid about it hitting 50C. When my new heatsink comes in I may be able to try the 2.8GHz with your latest bios.
sideeffect I sent u a PM ;)
And i answered it about 10 mins after you sent it. Was yesterday i think didnt you get it?Quote:
Originally Posted by FlyingHamster
My chips are 505 double sided 512mb sticks. I havnt taken the heat spreaders off to take a closer look.Quote:
Originally Posted by Sonic9
well my stuff finaly came go start testing
[IMG]http://img398.imageshack.us/img398/3822/imga00312ar.jpg[/IMG]
a pic of modded booster a must in my book if ur using winbond with neo2 cause to much heat is in that confined area .plus with that my bh5 finally hit 275
[IMG]http://img386.imageshack.us/img386/5820/imga00330hq.jpg[/IMG]
[IMG]http://img386.imageshack.us/img386/8755/imga00347eh.jpg[/IMG]
I have a cold bug problem with my systems
MSI Neo2
Sandy 3500+ 512KB L2
Gskill TCCD 4400 LE
CoolerMaster RP450W
My system can stable at @300*10 on watercooling,
I've tried a lot of 1.36b, 1.37b, 1.9, A.1, sideeffect bios, but everytime when I set HTT over 240Mhz in bios (ex @280*10), if I turn off PC and turn on agian, it'll not boot. I have to clear bios and setting bios agian
Anyone Please help me. Thank for informations.
with every bios under 1.9 all you have to do is hit Insert then go into the bios and hit save changes
anything over 1.8 then yes you have to reset the bios.
dear god dude who modded that booster ?
i mean no offense but does that thing even run ?
what did they solder it with a torch ?
it runs
just finished the ram im in win testing now 250mgz ram
[IMG]http://img390.imageshack.us/img390/9260/imga00394ke.jpg[/IMG]
Fixes to Rev1 and 2
- Now all options available in bios will show.
- Full logo and small logo can now be enabled but are disabled by default
- Memory voltage default set to Auto
- Nvidia lan is now on by default.
Many people didnt like the hidden options so i re-enabled it all. Ill probably make a Lite Edition for those who like a cleaner looking bios with all the junk removed.
Any more suggestions on memory timings? Or shall i leave it alone now.
@ iMAX the 1.A4 is supposed to be better at dealing with the cold boot problem than the 1.A official did you try this bios to see if thats true?
Thats just what i have heard i dont experiance the cold boot issue with either versions but i did with the 1.9 bios.
LOL
No offence,, but man thats a mess :P
Is that hot glue?1?!
On that 1 pic of the booster it looks like theres a 1/4" of glue between the ram sink and the metal its mounted to? :P
If anything that HOLDS heat :P
And yeah crazy solder job :P
thanks :) :)
how do u run prime95 twice to test the cores
You have to run 2 instances of prime at a time to max both cores at once.Quote:
Originally Posted by msimax
D3kMatrix You need to update your bios list with the 1.A official and *cough* my bios :)
Yeah I know I have them all downloaded and on the server, but I need to get to bed, work at 6am =(Quote:
Originally Posted by sideeffect
So tomorrow it will be updated :D
when i click on the icon twice it doesnt give me two windows
Thank a lot , but where can I download 1.A4? :p:Quote:
Well you can get it from Here
Thats the Murdok version.
I just modded a version with the 183, 150 dividers but its not ready yet. Murdok is going to mod it with defaults.
Thank man, I'll try it ^_^.
this thing sucks cant do 2.6 on any voltage or any core
