It's normal for those chips at those steppings to do 3Ghz @ 1.5v+ I wouldn't worry until you get to 1.67v and up and load temps of >50C, just keep it at 40-45C on full load and <1.67v.Quote:
Originally Posted by gearhead364
1.57v is not a bad thing as most people don't keep their systems longer than 5 years anyways.
If you plan on putting a waterblock on the chip I would recommend taking the IHS off :D Just do your research and you'll be fine, you're on one of the best forums for it.
good luck.
P.S buy this to replace your chipset fan with the vc-re chipset fan at: http://store.yahoo.com/cgi-bin/clink...Fb+vc-re.html+
& I would mount a small 97mm fan over your pwm area to keep those temps down. also some good cable management can help some more in lowering temps. last but not least,. buy a giant fridge and make that your computer room, atleast you won't have to go far for the beer ;)
