Originally Posted by 2virgule5
Just had a try of last sideffect modded bios : 150 option is not listed (only 100, 133, 166, 183 and 200), but 183 option did work well, I'm now running my X2-4200+ at 240 x 11, RAM is at 203.1 Mhz. I'll try higher HTT @ x10 later. CPU voltage (as read in bios and with CPU-Z) dropped by 0.05 to 0.1 v when I select 1.55 vcore +10% (it is at 1.55, was about 1.6 to 1.63 with 1.A3 with the same settings).
Another good news : it also seems that the cold bug disappeared, as I now can cold boot without problem at those settings (I had to reset CMOS at those with crappy 1.9 and 1.Ax).
Thanks for the work !
