Heat Guns -
Question to those using heat guns - what heat settings you use? For example, I just picked up a cheapy ($14) that does 250C (482F) on Low and 450C (842F) on high - How does that compare to what you are using.
As for backround - kinda got tired of using my torch lighter which can burn the sleeving or heatshrink if you are not careful http://www.google.ca/imgres?imgurl=h...w=1280&bih=656
