This will be my last post here guys, I upgraded to the Asus Blitz Formula SE since it has way more bios settings such as the Loadline calbration which eliminates the Vdroop issue. Anyway, the reason I am posting is that I thought some of the folks looking for some decent ram would appreciate this. I got the OCZ SLI 4GB kit (
http://www.ocztechnology.com/product...n_dual_channel) and was able to overclock it stable (OCCT stable) to 1066. Here are my settings:
Cas Latency timing - 5
Ras to Cas - 6
Ras precharge - 6
Precharge delay - 21
Refresh cycle time - 60 (very important for stability)
twr - 4
twtr - 4
trrd - 3
trtp - 4
command time - auto or 2t
memory enhancement (cant think of the stupid name) - options are standard, turbo and extreme - select turbo
for the rest of the memory timings leave them to auto
My FSB is 444x8 for my Q6600 with a memory divider of 2.4. Set the voltage to 2.2 ( this is within spec and will not void your warranty according to OCZ website)
This for 4GB of ram (2x2GB) and you can get them for around $65 after MIR from CompUSA's website and from Newegg
http://www.newegg.com/Product/Produc...82E16820227269
http://www.compusa.com/applications/...&Sku=O261-8038
Hope that helps out everyone.
Good luck and happy overclocking!!!!
Utnorris
