They are AADT if u look at the pics.
iirc that is not good for overclocking.
250FSB is good to me.
holy crap fellas,,,,
why arent you people loosening them up to see what they can really do,, so you dont kill the stuff overvolting. i know it will handle it but for how long.
how far is this ram going when you run. 2-3-2-6 or 2.5-3-2.8 or 10
i mean no need to get all crazy and let them real loose but use realistic settings like 2.5-3-2-10 for A64 that :banana::banana::banana::banana: should crank out way past 300mhz.....
anyone tried this yet ?
I tried for 300Mhz @ such 2-3-2-7 3.4V....posted but failed thru boot. Never tried lower.Quote:
Originally Posted by Lestat
it'll give you a couple of mhz,Quote:
but not much.
it reacts like bh-5; so not much gain in mhz, big loss in b/w after loosening timings.
someone needs to pick up the regualr ddr400at $105/gig and see if they are still utt!
its confirmed,they are still UTT,Klisp has some...I jsut hope they dont go out of stock before I buy em...damn ppl buyin 10s...damn them :(Quote:
Originally Posted by __TRONIK__
I just pulled the trigger for the "vanilla" TM 3200's, I'll let you know what chips are on them later this week.
:toast:
512mb sticks are back in stock at the egg. 22 left at 10:55pm est $69!
Originally Posted by sparkie34
Yea,I saw those too...last time I looked there were 24 in stock.
has anyone seen Mushkin UTTs? some guy told me mushkin reps guaranteed UTTs on some ram...
/me hears the click-clacking of furious keyboard pounding :p: :lol:
You lucky guys in USA :(
guys i need some help here with my vx gold...on my dfi nf4...
i have been looping memtest this morning @ 260 with the following settings:
1.5-2-5-2-7-15-1-2-1-2-auto-1-en-incr-0-7-4-auto-auto-auto-dis-8-7-en
vcore 1.75
vdimm 3.6
vltd 1.5
chipset 1.7
bios 2.18 (tried 3.10 but was told to go back to 2.18)
those settings will do test 5 for 50 loops and i looped tests 1-8 and right now i have test 8 looping - so far it has done 10 passes...
so i think that things are stable enough for me to try to get into xp - as soon as the xp loading screen comes up - my keyboard initializes - bam BSOD......and i get the bsod right after my keyboard flashes - every time.
the 3500 newcastle is good for 2.6ghz and the ram wont error out in memtest so i dont know what setting i am using that is making xp puke?
anybody have any suggestions?
Well, memtest only tests the A64 core's ability to access memory. All the other things in the system arent hammered....til you try and boot windows.
Obviously something in the system cant hack those tight timings. So back off till it works, and then try to zero in ONE item at a time to figure out what timing parameter is too tight. Its laborious I know but its the only way to identify what is holding you back.
ok well i am at a complete loss - i thought maybe one of the settings is too far out of wack for my hardware.......so i put every single setting to auto
voltages / dram settings - everything is auto
should be able to get into windows with auto eveyrthing right?
wrong
bsod - same spot every time.....and i know its not the board or the cpu cuz if i pop my tccd in its fine - past 2.6ghz so it has to do with this vx :(
Bought some sticks last night will update once I get em :D
heya :) i just orderd 2 sticsk of this winbond UTT stuff... seems u need around 3.2 - 3.4 volts or so to get it to perform... is that safe for 24/7 use??....
im just a bit worried i will damage it... and if its not good for 24/7 at this volts.. what do u all do? just use differnt memory for everyday use and swap to this for benching? thnx for any help.... :)
OCZ warrants their ram up to 3.5V and they use UTTs so I guess to be safe use it at 3.4V IMHO.
Its pointless to buy ram if ur gonna use it for benching alone lol
Originally Posted by Negative Design
3.5 and 3.6 is safe too, if have you have the mems proper cooled with a high CFM Fan
But if your DIMM doesn't respond to Voltage raise, don't try more than 3.3-3.4
you might kill it
is my first a64 rig ive built.. still waiting on part to arrive... orderd 1 o them ASBOX 3500 cpu`s in the other thread..... but was worried i couldent use this memory all the time 24/7 and high fsb... glad i can!!!:) im using a xp-90 HS on a dfi lanparty ultra-d mobo... im not sure how that HSF sits on the mobo.. so dunno if it gives the mem a bit of extra cooling.... i dont have anything else to cool the memory with :/
Just a quick question bout UTT in general; is 3.3v enough to get a pretty good showing out of this stuff or do I really need 3.4-3.6v?
thanks
Mine wouldn't do crap with 3.2v, but with 3.28v they would do 244MHz @ 2-2-2 timings on my NF7-S. I think its really hit or mis, some take to 3.2v, others need upwards of 3.4v to start performing. Mine were 44d, 0605 chips.
Originally Posted by Chivalry
depends on your setup
A64s+3.3V should give at least 245MHz
thnx :) put my mind at rest a bit... just gotta work out what all them bloody numbers mean now! lol..... never seen so many settings in a bios!!! :) hehe
Newegg has the speed premium in stock right now just checked them.
