Going out to get 55L of LN2 for the 980x 3003B475...
Wish me luck!
Wish me luck!
Good luck! :up:
Many nice scores have been posted today, especially Linuxfan has been very busy! Good work everyone! :)
http://img830.imageshack.us/img830/3...ber6th2010.jpg
LN2 is here are waiting. Prepping OSes and insulating in the morning then BENCHING! :D
Thanks for the update Daniel.
The laptops were fun to test. Actually still have some more CPU testing to do. :up:
Friends don't let friends use kneaded eraser.
3 layers of Conformal spray & vaseline.
Much better in every single aspect.
Whats wrong with eraser?
And btw linuxfan, lovely looking setup :)
What pot you using?
Linuxfan, you hear about the new Mushkin sticks? It's like gluing a Redline to a Ridgeback... because they are... REDLINE RIDGEBACK!
Gotta do conformal just haven't jumped on the board yet. ;)
Thanks George!
Eraser doesn't insulate the board as well as a complete coating of rubber and you have to install it each time you want to bench.
The CPU pot was made by Ryba.
Here's what I was able to get today... I'm sure there's more clocks in the CPU though still feeling it out.
Superpi32M, 1M, and pifast next. :up:
Kneaded eraser is good for "low" temp benching, as in temps being hold nearly statically in the -70 to -90C range.
For any kind of long term benching with seriously low temps ( -120 and higher ) kneaded eraser is only going to cause issues, it's going to get moist, and in an hour or so you'll be having water dripping in every corner of it.
Ah fair play
Even in the -30 to -40 range I sometimes get bleeding, but othertimes I don't, not sure why
Haven't got that cold yet (sadly :( ) so I guess I'll just have to find out.
xs is coming up on the single core challenge! great job you guys!
What are you running Linuxfan ?
Was running a lapped Q6600 G0 with some Crucial Ballistix D9 mem in a EP45-UD3P rev 1.0 board but had a CBB. Wasn't sure where the hot gas bypass valve was so I just had to shut 'er down. :(
Found it and am ready to roll today.
Will either test out the Q6600 on Cascade, Q9450 for the gold(and hope it doesn't CB at -120oC) or slap a Ceader Mill CPU in my DFI P35 T2R board to try for some 7ghz+ CPU-Z action on LN2(either the 347, 356, one of the 631s or a 651). :up:
Too much to do and too little time. ;)
Try lowering the CPU PLL Voltage ( sub-specs ) it may lower the CBB & CB.
In the most recent stage of the ASUS 1156 Overclocking Championship, two of our members entered Top 10, chew* and FUGGER came in 5th and 7th respectively. Zeneffect made 15th place in this stage!
Good luck for the next stage! :up:
In HWBot's OC Challenge October, thanks to some excellent submissions by chew* and G.Foyle, the team is currently ranked 2nd in the overall ranking, while still holding the record in the 3DMark Vantage stage. Nice work! :)
Tested the Q9450 on my EP45-UD3P rev. 1.0 board with the cascade...
Seems like the chip doesn't like to be overfrozen, didn't get much farther with clocks than my runs with the EP45T-UD3LR board and the SS unit. Seemed like it had a coldslow or something though, results started getting super slow at high speeds. :shrug:
Might try on air tomorrow and see what I can figure out.
Cascade runs great. :D
me and chew this past weekend. massman wont let me submit in the oct. contest with his card. but for the record.
http://hwbot.org/community/submissio...870_9827_marks
The score Chew* got was higher so it wounldn't make a difference at all if you posted that score.
Its great that you were able to bench with Brian this last weekend, I'm sure it was a good experience. :up:
Why don't you try some PCMark sometime with your three SSDs? I"m sure that'd be fun. :D
