Then you probably didn't find your optimal MCH Ref.
you guys are amazing, the fatal error final results was xxxxxxx, expected xxxxxxx in prime95 is due to the temperature
i changed to a ek supreme lt and temperature droped a few degree, but i still get core 1 and 3 higher than 67 under 1.4v @ 4.4ghz
so i try lowering the vcore and as the temperature drop, it gives more successful tests in prime95
but because i am not putting enough vcore, bsod come soon
so now i changed the block, and am going to the rad's fans
i am using this
http://www.coolermaster.com/products...ate=36&id=6037
and
swiftech mcr320
the dba is actually sick, it must be louder than that
so do u have any suggestion on fan that isnt louder than this and can lower the coolant temp more?(closer to room temp)
there isnt much choices in hongkong but please still suggest and i will go looking for
thanks
Well, the scythe fans have sony-made fluid bearings which will last a lot longer than the coolermasters, especially mounted flat (like on a radiator). I never have tried your fans though, so I can't really give a honest comparison.
Hi.
This is my 24/7 settings, 30 loops IBT maximum stress level stable, all aircooled, bios 1307.
Priming for 8h so far...
http://img140.imageshack.us/img140/5...remesystem.png
Testing the GSkill F2-9600CL5D-4gbpi.
http://img190.imageshack.us/img190/3...200mhz240b.png
http://img21.imageshack.us/img21/5350/cachemem2.png
http://img196.imageshack.us/img196/5236/bestyzs.png
OC Nub,
First: Congrats on that CPU, is a monster!!!!!
Second: I just looked at your everest numbers at 4.5GHz /500FSB / 600MHz DDR2, and compared to my 4.2GHz / 467FSB / 560MHz DDR2, and it is strange that my L2 cache bandwidth in everest (its where the 2x6MB cache is) is higher? How can this be? I think we have the same setup, only I have Asus board and you have Gigabyte... Is that normal? Would care to post that everest bench at 4.2GHz / 467FSB / 560MHz DDR2 for a comparison? I sure can't clock my CPU at 4.5GHz!
tkx.
what q9650 @ 4.6ghz/ep45-extreme can do @ real apps
http://www.youtube.com/watch?v=MvBKB2NndbI
the same all air cooled q9650/ep45-extreme ive posted results here earlier
Passed blend, happy not to have to run 1:1 anymore. :D
http://img32.imageshack.us/img32/204...5001200mem.png
^ congratulations. My new memory comes monday, I can't wait.
thanks :toast: q9650+ep45: very capable platform :up:
Thank you Sergio.
Napalm: That is insane. Very nice :up:
Thank you.
You order the 9600 GSkills?
Marcio: I am not sure why the numbers are lower there either. If I get time I will test at 4200mhz this weekend. This is another test I ran, similar results as before.
http://img41.imageshack.us/img41/5320/everestbench2.png
ocnub - keep it up ^ :up:
thanks guys :toast:
faster mouse but the human element also needs upgrades.. look at my clicking.. brain/eyes/fingers/mouse/mouse pointer.. i need faster communication between all these :D
Amazing job OC Nub and andressergio...I have no idea how you're getting 4.5GHz...amazing. Could you two please post your BIOS settings? Mainly the voltage and mem settings.
Nope, the ocz blade 9200s. I couldn't stomach the $159 price for the tridents or the pi. Thes were $85 with free shipping. Every single review I've read says they will do 1200. We'll see.
Very nice chips, guys :up:
