yes but would it fit vertical? I know ofc horizontal wise would fit, but I got my doubts on vertical..
Did he say 27 hours of prime captain
http://www.youtube.com/watch?v=8Q5EX...eature=related
J/K
Stabe is as stable does, that simple. Everyone has what they determine stable. I myself like C-N's approach, 32M runs/X amount of Prime/X amount of gaming and G2G.
I tried some sub zero ambient love with the new found Winter weather and it was a bust. Couldn't get anything working. I think the resistance on so many things changes so much that to figure it out would mean more risk than I am willing to take. It is about -20c outside and hate to damage anything.
Odd thing was Everest and Coretemp wouldn only read my cores to 8c-8c-4c-4c. I know they were allot lower than that at 1.15v on the cores :)
Oh well, it was worth a shot. :)
Ha Thats a good one.
Hey don't matter to me. Each to his own as they say.:shrug: As long as it works!:up:
I usually only do overnighters on work days. Get home from work, set up an OC and prime until I get up in the morning. If it fails I change it after work and if it passes I turn it off and go for something else when I get home.
What on earth do you do that requires stability with that kind of stress on the CPU? I have a system that at its current settings fails prime within minutes, yet does everything just fine. Music encoding, F@H, compression/extraction, Source 2007 games, etc. I haven't had a single crash.
8-10hrs is way more than enough for me! Maybe he's hosting bomb building seminars :rolleyes:
What was mentioned by Seanies Show does hold some merit. C-N has been very kind to be aiding me via PM's over the last couple of days so as to not clog up this thread with my whining for help. He pointed out as well that it takes at least 9.5 hours before prime is fully finished all of its tests and it restarts. After my failure at 8.5h I realized something must be amiss as technically prime was still testing new FFT's and not older ones all over again. The Solution? Disable GTL's and set the GTL buffer strength from Strong to Weak. Works a charm and I am currently running at near 10.5h at HIGHER settings than I was yesterday when prime failed at 8.5h. GTL's and me just don't play nicely together. From now on it is 10h minimum for me on prime if not more. I am going to keep this going probably all day, if it still keeps up that will be about 17h worth of prime. I will consider that stable and call it a day before I test higher tomorrow. Thanks to everyone for helping me, especially Praz and C-N, you guys are a great asset and I appreciate all your input.
thanks c-n finally completely prime stable for 10 hrs with 2.1vdimm.. if heat wasnt an issue i would go higher.. i using crucial ballistix and team xtreem c4 for 4gig stable.. this is the best i can do with mix sets without using too much vdimm.
http://img135.imageshack.us/img135/7738/4gigsbp9.th.jpg
My experience tells me that if Orthos doesn't crack after 2h it won't do it at all.
I only let it run for 12h when doing 24/7 settings.
Kinda confused which temp is getting it right...:confused: :confused: :confused:
ALL stock settings...
using TRUE...
ambient temp 29c...
http://i116.photobucket.com/albums/o...temp-stock.jpg
cpu temp is off approx. 15c on the software so add 15c to the cpu temp others are about right.
I have a trouble, by installing the module sound "Bernstein audio"
the computer starts and posts the code error 25, when I go in the bios and I disable the function of sound "HD" the PC arrives under Vista
My rig
QX6850
DFI P35 ut t2r
crucial pc8500
8800 ultra
somebody has a solution please?
Ok ....building a rig for a friend and would be the most grateful person if someone can give me a screenshot of their Bios using Ballistix 8000 or 8500 and an E6600 / or what you think will work with an E6600 This is the LT version of the board but all i need are settings that will let me OC it to 3.4 ...does 3.6 on my icfx3200. thanks in advance!!!
I know its funny as hell when Lestat Posted that:rofl: :ROTF:
:eek2:
love your avatar Campbell!:up: :ROTF:
