im going to test them next on the new board:D
yea im good for 500fsb 1200 pl8 with 1.30v NB so far with this new board.
this kit does 1300 with 2.25v real so far:D
Thats really impressive- hard to find kits these days that even do 1300- the better if it needs only 2,25:D
heres a quick memtest shot.it would error out at 2.22v real so i moved it up a notch:D.
http://i53.tinypic.com/w175a9.jpg
well it looks like the lowest i can go at 500fsb 1200MHz PL8 is 1.30v NB.
http://i52.tinypic.com/314yxkx.jpg
Would a Ballistix 2x512 8FD3 kit be any good? Seems like 16FD3 + 16FD5 are the ones to hit 1400+. Can't remember what serial my old 2x512 ballistix had, those would top ~1200. The kit I'm looking at now have the newer HS.
edit: At least I think this are the new style
http://www.auphanonline.com/articles...54_500x500.jpg
my old kit looked like this
http://www.prisjakt.nu/bilder/bild.p...&size=800&.jpg
Should run OK- the 8FD3 is just because the sticks got only 8 ICs- the 1GB modules got 16 because of double capacity- give it a try, should be D9G for sure^^
Yes it was D9GMH. No, they weren't good ;)
Too bad you are so far away from germany:p:- since I am selling a good kit of Ballistix PC2-8000 and some CS 8000 Cas4 that are doing 1300 Memtest stable under 2,2Volts:rofl:
P.S. Sad to hear the BallistiX su.. - friend of mine had the same kit that did at least 1280 C5 32M with 2,3Volts
Actually the best stick can do 570 4-4-4-4 32M @ 2.675 vdimm. Despite this I can't pass 600 5-5-5-15 :shrug:
The other stick is really bad, probably degraded.
Yeah, 1300 @ 2.2 will only be a dream for me :up:
Just remembered my Ballistix 1000 with DQT- sold earlier this year, no time for nostalgia :D
http://www.abload.de/thumb/d9dqt1000c432m222v3gzjq.jpg
http://www.abload.de/img/crucialfb1kvln.jpg
I think I have finally found some good gmh's, anyone here having experience clocking ram with nvidia 780i sli chipset? I want to know if it's "real" frequencies :) My commando hates ram above 1200 so I'm not using it.. instead a crappy p5n-t dlx with 1100fsb and ram at 1200. Booted 4-4-4-12 1200 @ 2.63 but not stable.
Normally Ram-frequencies and Timings shown are correct- I had 780SLI as well, with some rams itīs a good clocker but not with all, sometimes compability su***. 2,63V boot 600 C4 is possible with good GMH, I tested one of my Crucial kits when I owned the XFX Tripöe SLI 780i for a short time and 550 4-4-4-10 @2,2V fully stable were no problem, and this was definitely not the max
As usual, against your ram I cannot compete! Gave up on the crappy nv chipset, I can run 560MHz on commando before I run out of fsb (crap cpu, E2160). Lowest stable 32m volt is 2.40 from bios, 4-4-4-4. No use for ddr2 anymore but I couldn't resist these sticks when I saw them for sale :)
I still love DDR2, but because itīs easier to cope with two DDR3-systems (compare and check) I sold my last DDR2-Board and all of my ram:( - got two kits left for backup for it is getting more difficult from day to day to get good kits, so Iīm the one out of competition :D. 2,4V for 560 C4 on Commando means your ram is good, so I think was a purchase worth the money :)
P.S. just for the record, I also had 4-4-410 with same V but canīt find the screen-chaos FTW:rofl:
http://www.abload.de/thumb/balistixn...m1100-znkd.jpg
Nice to see guys still pushing the DDR2 D9's :D Some of my best PC memories are with these kits.
I sold all my DDR2 boards and all but my very best kit of D9's - a Team Group PC6400 C3 kit. It sounds weird but I'd like to get these framed and hang them in the study.
this thread still alive ? :D:D:D I got some DDR2 last week, but no Board :D
comin soon
You mean Ram like this? :D
http://www.abload.de/thumb/1m533.-2jpge4aj.jpg http://www.abload.de/thumb/af32m500-667-2z6dp.jpg
Team XTreem D2-800 C3-3-3-8 @ 2,2V on GA P45-UD3:hm: :D
Sold- I have two Ballistix Kits running better left, they are now rotting in my closet:rofl:
Ok this is the best I can do with these sticks given the cpus and mobo I've got. Doesnt scale with more than 2.60 vdimm.
http://imup.se/i/9xoLcptoSl.png
Max 32m stable on dirty OS.
http://imup.se/i/hPw7OLtWTb.png
Not my goal of 600 cl4 stable but it's good enough for me :yepp:
Same kit yes. My result Here
I never pushed them harder, would have loved to do 32M at 690 MHz + but at 683 MHz I'm in a pretty small group of people who have done it.
I remember discussing with you perhaps a year or 2 ago what some of your best kits could do. They were just amazing, but my C3's were the best I ever had. Did DDR2-1200 MHz 5-5-5-15 at 1.91v IIRC.
Very nice, I'll give you a week before it wears you down and you make 600 CL4 heh ;)
hi,
can anybody give me advice on where to buy 2x1GB DDR2 D9GMH/D9GKX ?
I sold all my old stuff long time ago and it seems that was a bad decision...
it is so hard to find any of those, yesterday missed the auction of 2x1GB Cell Shock 8000 (d9gkx) were sold for 32$ :(
Yeah hard to find now. I sold most of my kits for $30 each :( Had 2 Cellshock PC8000 CL4 GKX kits, one was only tested briefly and put back in the box too.
Keep your eye on forums and ebay, maybe put up a wanted to buy thread too. Good luck.
I bought 2x1GB D9GKX's this morning :)
i also found some 2x1GB Micron D9LPF chip. The seller is quite weird and has not much experience in OC but ensured that the rams goes easily over 1200MHz on def. voltage full stable (memtest)
Is anybody familiar with these sticks ?
http://img11.imageshack.us/img11/7295/captureenj.th.jpg
This is the first time i hear about d9lpf's to be honest :D
D9LPF seems rare and untested. I doubt it performs as GMH/GKX, but hey try it out :) I remember a set of 2x512 elpida ddr2 sticks that did 1200 4-5-4. Maybe LPF can surprise too.
That's pretty nice, the Commando is still a great board. :)
Do you have a "real" CPU so you can try to do this at 1:1?
Also, what's your Vmch for this run?
If they aren't expensive please buy them and report back!
I've never heard of these chips either, so it should be quite interesting to see how they overclock.
