As always, I've tested the modded BIOS and can gaurantee it works. For other P5Q mBIOSes, I can't gaurantee they will work because I don't own every single P5Q Series board to test. I can only say for the mBIOSes I'm unable to test I'm 98% certain they will work but should you choose to use any of the modded BIOSes you do so at your own risk of knowing sometimes BIOS flashes just go wrong. So have a recovery plan handy - just in case.
P5Q Changelog:
- Update memory table to P5Q Pro Turbo 602
- Update P6 table to P5Q Premium 2406
- Update Marvell O-ROM to 1.1.0.L73
- Update intel O-ROM to v9.6.0.1014
P5Q Pro Changelog:
P5Q-E Changelog:
- Update marvell PXE to v6.60.2.3
P5Q Deluxe Changelog:
P5Q Premium Changelog:
P5Q Pro Turbo Changelog:
P5QL Pro Changelog:
P5QL-EM Changelog:
P5QL-E Changelog:
As for overclocking potential.. no idea. It should be better than any vanilla BIOS. Its also worth using these mBIOSes (where applicable) if you are experiencing SSD compatibility problems, the updated intel O-ROM should fix most.
P5Q Series mBIOS DL
