Processor: E8400 E0
Code:
Ai Overclock Tuner: Manual
OC From CPU Level Up: Auto
Ratio CMOS Setting: 9
FSB Frequency: 500
CPU Clock Skew: Delay 300ps (This Gave me more stability at the same vCore - - Thanks CryptiK)
NB Clock Skew: Delay 400ps (This Gave me more stability at the same vNB - Thanks CryptiK)
FSB Strap to North Bridge: 333
DRAM Frequency: DDR2-1000MHz
DRAM CLK Skew on Channel A1: Auto
DRAM CLK Skew on Channel A2: Auto
DRAM CLK Skew on Channel B1: Auto
DRAM CLK Skew on Channel B2: Auto
DRAM Timing Control: Auto (For Now)
DRAM Read Training: Disabled
MEM. OC Charger: Enabled
Ai Clock Twister: Auto (For now)
Ai Transaction Booster: Manual
Common Performance Level: 10
Pull-in of CHA PH1: Disabled
Pull-in of CHA PH2: Disabled
Pull-in of CHA PH3: Disabled
Pull-in of CHB PH1: Disabled
Pull-in of CHB PH2: Disabled
Pull-in of CHB PH3: Disabled
PCIE Frequency: 100
CPU Voltage: 1.341 (Droops to 1.336 under Load)
CPU PLL Voltage: 1.54
FSB Termination Voltage: 1.16625
DRAM Voltage: 1.9
North Bridge Voltage: 1.35
South Bridge 1.5 Voltage: 1.54
South Bridge 1.1 Voltage: 1.12 (Those because i have Raid)
CPU GTL Reference (0): Auto
CPU GTL Reference (1):-30mv (This means 0.64x anything else at tha 0.61x - 0.67x Range cause prime to stop)
CPU GTL Reference (2): Auto
CPU GTL Reference (3):-30mv
NB GTL Reference: Auto
DDR2 ChA Reference Voltage: Auto
DDR2 ChB Reference Voltage: Auto
North Bridge DDR Reference: Auto
CPU Configuration:
C1E Support: Disabled
Max CPUID Value Limit: Disabled
Intel Virtualization Tech: Disabled
CPU TM Function: Disabled
Execute Disable Bit: Disabled
Load-Line Calibration: Enabled
CPU Spread Spectrum: Disabled
I tried those settings with multiplier 7.5 with FSB 440 for my Q9300,ended up getting bad vista installment + no hope to login in windows.Is my Q9300 Really this bad that it wont go anywhere without settings being auto or over 3.3?
I tried those settings with bumbed values,no go. This really is disturbing me.
I got 280GTX,4x1gb DDR2 800Mhz corsair,750W P&C Silencer Quad,Q9300,M2F mobo with bios 1802 and Vista ultimate.
Any help would be appreciated.
