Well id use the ich10 controller anyways as its the fastest atm, unless yes you have a RAID card.. IIRC only 6gb ssd out is the current c300 atm.. When the c400's / g3 hit then i believe we'll be seeing more of sata III ;)
The sandforce based SSD's look to be even faster than the C400 and G3. So i really dont want to use an SATA 3GB/s controller, it would seriously cripple it. And being as Intel are not releasing a high end 6/8 core Sandy Bridge CPU for ages yet i'll be sticking with this board and my 980X for some time... this is why i'm looking for a way to get 6Gb/s for a pair of RAID sandforce SSD's when they come out :confused:
Not sure if this been posted but new bios rev 1.0 F8g Beta
Read so many pages of this thread and couldn't find my answer, is v2 better for overclocking or is v1 ? :shrug:
EDIT: Is it normal while posting that it doesn't show the CPU info only the memory frequency ??
EDIT 2: Thought I would share my Northbridge 1/2" mod :)
http://i581.photobucket.com/albums/s...rbid/jinya.jpg
Im not sure what your saying, but rev 1.0 of the ud7 overclocks better..
Vs rev2?
I don't think so mate!
so the Rev 2 beats the Ud9 ?
ud9 is a complete different motherboard , twice as much as has twice as many PCIE slots.. I wouldnt call it better in terms of overclocking.. As for the rev 1 has 24 phase power, rev 2 has 16, i dont know if the 16 is more powerful, but it does seem to be a diffrent design, and that is why they thought the rev 2.0 should only have 16. The ud5 rev 2.0 has the same 16, and aside from the heatsink not being a water block they are the same boards, both rev 2.0s.
rev2 is same as rev1 for std cooling but on LN2 it is a bit better than rev1 and about the same as UD9 :up:. The PWM is a bit better for very high loads with a 980X and high volts. Yes the new 16phase is a bit more powerful for LN2 benching than old 24phase as each mosfet is rated higher and they are more efficient in delivering power
Thanks dinos22 .:up:. might sell my rev 1 and use the newer rev 2 I picked up yesterday, even I wont be using LN2 it sounds a better board ..
For xtreme clocking, "subzero"
I was having some issues so purchased a new motherboard. I do understand it would most probably only be beneficial with LN2.
Yo guys,:)
does anybody have a link to download the latest EasyTune6 ?
Here ya go mate..
http://download.gigabyte.ru/utility/..._et6_intel.exe
Hi there...
I need to put a question to UD7 users. I have a X58A-UD5 rev 1 ... do you think upgrading to UD7 rev 1 is a worth upgrade overclock wise ... or ... it won't have huge gains with the 24 phases... ?
i think it woudl be worth the upgrade if somthing is limiting your chip, if you aren't going for 4.8ghz+ then don't bother.
