I know I am missing out not using that 9600 gskill ram but I have a hard time paying that much for ddr2 mem. I know it use to be much more expensive but still with the price of ram now it is hard to fork out 140 USD for a
4gb kit of ddr2
4gb kit of ddr2
I was waiting and waiting for the OCZ 9600 LV Blades to come back in stock seems how they are quite a bit cheaper, but who knows when they will be available again. I got tired of waiting and the Tridents are in stock so I went with them.
I am curious to see how they do for you. I am tired of waiting also. Keep us posted please.
Nice OCs on the Q9650s guys! I'm going to try and get better results on HWBot with my Q9650 next week here, last time I tested it I hit a barrier with some 800mhz ram running at 1050mhz, I have a nice 1066 set now...
Very nice low Vcores also, I've been using more for each clock. :up:
Took some sheets of plastic and formed duct going from my ac unit to my rad, Everest reads my CPU temp at 22c idle now at 1.3v :shocked:. Will try and get 4.5 stable this weekend and catch up to you Sergio. Think this chip may need some burn in time though. Have only had it a little over 1 week.
22c and dropping :yepp:
Ok ran 14 minutes of 8k to see how temps were. 55c isn't bad for this cpu.
http://img34.imageshack.us/img34/9248/8ktemps.png
Thanks Sergio. Finally was able to do a short blend run at 4.5ghz, 3hours no errors. :D Will mess with it some more this weekend. :D
http://img79.imageshack.us/img79/3946/453hours.png
hello,
want to now why the cores under prime95 are getting different test numbers?
for example finishing a 20K test, core0 may take 15, core 1 take 11, core2&3 take 14
where core 0 , 2, 3, usually are variable
Hey guys, what were your MCH core voltages running at when you did your record runs at 4.7ghz+? I've not had mine over 1.46v I think...
Thanks.
Thank you Sergio.
LinuxFan: at 1:1 mem I was using 1.460vmch, but only ran 3dmark 06 successfully. Failed SuperPI. Need more than 1.46v for any stability.
Thanks for the help on the MCH voltages, never knew that... hopefully I can get a better clock when i raise that, I wasn't sure how far I could go and didn't want to burn it up.. :ROTF:
Just keep a good fan on the nb.
and pull off the cover plate
Yeah I figured I need some nice airflow on it when I run it that high... there's going to be good airflow through it all, I have many fans to go with the WCing setup, I think it'll be ok there. Don't think I"ll pull off the plate for the NB though, would it help the fans cool it a lot?
Thanks for your helpfulness!
thanks for your help
different time for finishing the test should be normal right?
but how about the number of test?
like i run small fft, if 3 cores take 16 tests to finish a 20k test, the other one take 15, would there be any problem? or meaning unstable?
thanks!
i am really having trouble to 4.4ghz
running this setting can get me passes 20 times IBTCode:******Motherboard Intelligent Tweaker (M.I.T.)******
Robust Graphics Booster.........................[ Auto ]
CPU Clock Ratio.................................[ 9 ]
Fine CPU Clock Ratio............................[ + 0.0 ]
CPU Frequency 4.33GHz............................[ 482 x 9.0]
******Clock Chip Control******
CPU Host Clock Control..........................[ Enabled ]
CPU Host Frequency (Mhz)........................[ 482 ]
PCI Express Frequency (Mhz).....................[ 101 ]
C.I.A 2.........................................[ Disabled ]
******Advanced Clock Control******
CPU Clock Drive.................................[ 1000mv ]
PCI Express Clock Drive.........................[ 1000mv ]
CPU Clock Skew..................................[ 0ps ]
MCH Clock Skew..................................[ 0ps ]
******DRAM Performance Control******
Performance Enhance.............................[ Standard ]
(G) MCH Frequency Latch.........................[ 400 ]
System Memory Multipler.........................[ 2.00B ]
Memory Frequency 1066...........................[ 964 ]
DRAM Timing Selectable..........................[ Manual ]
CAS Latency Time................................[ 5 ]
tRCD............................................[ 5 ]
tRP.............................................[ 5 ]
tRAS............................................[ 15 ]
******Advanced Timing Control******
tRRD[3].........................................[ auto ]
tWTR[3].........................................[ auto ]
tWR[6]..........................................[ auto ]
tRFC[52]........................................[ 52 ]
tRTP[3].........................................[ auto ]
Command Rate (cmd)[0]...........................[ auto ]
******Channel A Timing Settings******
Static tRead Value [ 8 ] ................[ auto ]
tRD Phase0 Adjustment [ 0 ] ................[ Auto ]
tRD Phase1 Adjustment [ 0 ] ................[ Auto ]
tRD Phase2 Adjustment [ 0 ] ................[ Auto ]
tRD Phase3 Adjustment [ 0 ] ................[ Auto ]
tRD 2rd (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2wr (Differnt Rank) [ 6 ] ................[ Auto ]
tWR 2rd (Differnt Rank) [ 5 ] ................[ Auto ]
tRD 2wr (Same/Difft Rank) [ 8 ] ................[ Auto ]
Dimm 1 Clock Skew Control.......................[ Auto ]
Dimm 2 Clock Skew Control.......................[ Auto ]
DDR Write Training..............................[ Auto ]
******Channel A Driving Settings******
Drive Strength Profile..........................[ Auto ]
Data Driving Pull Up Level......................[ Auto ]
cmd Driving Pull Up Level.......................[ Auto ]
ctrl Driving Pull Up Level......................[ Auto ]
clk Driving Pull Up Level.......................[ Auto ]
Data Driving Pull Down Level....................[ Auto ]
cmd Driving Pull Down Level.....................[ Auto ]
ctrl Driving Pull Down Level....................[ Auto ]
clk Driving Pull Down Level.....................[ Auto ]
******Channel B Timing Settings******
******Channel B Driving Settings******
******Motherboard Voltage Control******
Load-Line Calibration...........................[ Enabled ]
CPU Vcore [ 1.15 ]...................[ 1.38750 ]
CPU Termination [ 1.20 ]...................[ 1.30 ]
CPU PLL [ 1.50 ]...................[ 1.50 ]
CPU Reference [ 0.760 ]...................[ 0.87x( my memory is bad, but there is only one 0.87x ]
MCH Core [ 1.100 ]...................[ 1.320 ]
MCH Reference [ 0.760 ]...................[ 0.823 ]
MCH/DRAM Refernce [ 0.900 ]...................[ Auto ]
ICH I/O [ 1.500 ]...................[ 1.5 ]
ICH Core [ 1.100 ]...................[ 1.1 ]
DRAM Voltage [ 1.800 ]...................[ 2.100 ]
DRAM Termination [ 0.900 ]...................[ Auto ]
Channel A Ref [ 0.900 ]...................[ Auto ]
Channel B Ref [ 0.900 ]...................[ Auto ]
******Advanced BIOS Features******
Limit CPUID Max to 3............................[ Disabled ]
No-Execute memory Protect.......................[ Disabled ]
CPU Enhance Halt (CIE)..........................[ Disabled ]
C2/C2E State Support............................[ Disabled ]
C4/C4E State Support............................[ Disabled ]
CPU Thermal Monitor.............................[ Disabled ]
CPU EIST Function...............................[ Disabled ]
Virtualization Technology.......................[ Disabled ]
running this setting cant get me pass IBT 20 timesCode:******Motherboard Intelligent Tweaker (M.I.T.)******
CPU Frequency 4.4GHz............................[ 489 x 9.0]
CPU Host Frequency (Mhz)........................[ 489 ]
Memory Frequency 1066...........................[ 978 ]
CPU Vcore [ 1.15 ]...................[ 1.4250 ]
CPU Termination [ 1.20 ]...................[ 1.40 ]
CPU PLL [ 1.50 ]...................[ 1.57 ]
CPU Reference [ 0.760 ]...................[ tried 0.886~0.971 (5 options) ]
MCH Reference [ 0.760 ]...................[ tried 0.886~0.96x( 3 options) ]
ICH I/O [ 1.500 ]...................[ 1.57 ]
ICH Core [ 1.100 ]...................[ 1.2 ]
DRAM Voltage [ 1.800 ]...................[ 2.100~2.14 ]
there is no bsod just the screen freeze, the best one is passes 6 times
any idea?
using giga p45 ud3p
thanks!
I replaced the old window unit behind my pc, got a 6500btu unit now blowing on the rad. This is still a hot running cpu but think I will be able to oc a little higher now. Ran a few minutes of 8k to test temps.
http://img139.imageshack.us/img139/3...tercooling.png
Some IBT test i did today on W7x64 7600
4320 1,328Vcore mems 2x2Gb 1152 PL8 Std profile
http://img148.imageshack.us/img148/9...328vcore21.jpg
4320 1,328Vcore mems 2x2Gb 1200 PL8 Std profile
This time using 2.05A divider wich needs looots of volts to get stable, image from some days ago
http://img213.imageshack.us/img213/8...vcoreibtma.jpg
4401 1,360Vcore mems 2x2Gb 1174 PL8 Std profile
http://img197.imageshack.us/img197/3...36vcore22v.jpg
