what kind of memory do you have??? my ram is limiting my overclock I need PC-1000 guys please meake me a recomendation :mad:
Oh, I can make you wonder some more :)
Same OC, CAS4, very tight subtimings too, only 2.1v on the RAM
http://www.izipik.com/images/2008021...cig6srp-14.jpg
Lokk at my signature for memory type I use
Hey Jonny
What are the advantages of the P5K premium over P5K deluxe
Cheers
Sergio
P5K Premium is supposed to have new PWM with better quality and less heat, to optimize quadcores overclocking. If you buy a new mb, go for the premium, if you have a deluxe, I don't think it is worth the upgrade as the deluxe overclocks very nicely on the forums
Hey guys, any tips for overclocking my Q6600 G0 ? Ive got it at 380 * 9 and its 12+ hours orthos stable. But i cant get the FSB any higher. i even went out and got a P5E to test it in but its still the same (Not to mention 2 billion options in the bios compaired to my P5B Dlx).
I can boot into windows at 450 FSB and my rams good for 575 + 5-5-5-15 @ 2.1 so it must be my settings.
Any threads that can explain the jungle which is the P5E ? Thanks!
http://www.xtremesystems.org/forums/...&highlight=p5eQuote:
Has anyone put more than 1.5V into a Q6600 on just water (as oppossed to phase). Temps seem ok at 1.425 but I don't think I can go further with less than 1.5.
What are your temps and clocks? I use 1.5v+ on air and it's fine (turns out my degradation issues were due to the bios, not the CPU).
Yes I have used 1.5v+ on water with no problem. My quad has no issues and can do 4150mhz.
Tried again to get higher then 9X425,no POST.
Tried everything on auto like some suggested and it didnt work...
my CPU is limited to 3.8 thats the only reason i can think of...
batch L731B.
What you guys think, keep a reliable q6600 @ 4050Mhz or go to the new q9450 and see if you can hit the 500fsb x 8 with it on my system (see siggy)?
Iīve a L731B152 (1.2375 vid).
This is the max i can do.
http://img169.imagevenue.com/loc1166...122_1166lo.jpg
I can run 3d mark but itīs very instable.
With this cpu i struggled to get it stable at 3.6:(
It seems itīs not a good one.
I've been running with 1.5v 9x400 on water for a couple of months without problems. Core temps below 50C.
I've just reinstalled in a different case and am trying to get to 8x450 or above. Seems stable at 8x440, but having some problems getting higher. Will keep trying :D.
Ok,
I can run stable 450Mhz x 8 or 422Mhz x 9, but I cannot get 450Mhz x 9 to hit 4Ghz. Temps are not an issue, I am water cooling, so my temps get to only 60 degrees under severe Everest load with P95 running also at 3.8Ghz and 1.5 volts. Anyway, I think all I need is a little more voltage, however on my Gigabyte MB (P35-DS3R) if I put the cpu voltage on 1.6 I only actually get 1.5 do to Vdroop. The next step is 1.8, there is no in between, and after Vdroop would probably be 1.7 or 1.75. I think this is too high for this chip, has anyone gone this high on voltage? Any advice on getting it to 4Ghz? By the way, I have added .2 to both MCH and the Northbridge voltages and that doesn't seem to help. My next step is to try and see what my FSB wall is, it may be possible to get to 475Mhz x 8 which would equal 3.8Ghz. Since I have already hit that with 422Mhz x 9, that really isn't much progress. Has anyone hit 500Mhz on this chip?
Thanks,
Utnorris
Well im back! some Pi action on my P5E. My Q6600 is a bad clocker me thinks :(
http://img183.imageshack.us/my.php?image=12sow7.jpg
Everything on air and ram's on 2.1v.
Has anyone gone above 1.6v on the cpu? If so, how far?
Thanks,
Utnorris
Johnny_FTM, isn't all P5K Premium supposed to be Rev. 2.xxx? How come yours still says Rev. 1.xxx according to that screen?
Are there two versions of P5K Premium? One is the Pearl (or is it black) edition and one is the normal color one? Am I missing something? I RMAed my P5K Deluxe. Hope I will get a Premium in return (which is what everyone is saying anyway).
