CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio: x9
- Target CPU Clock: 3402
CPU Clock: 378
Boot Up Clock: Auto
DRAM Speed: 333/800
- Target DRAM Speed: 947
PCIE Clock: 100mhz
Voltage Settings
CPU VID Control: 1.35v
CPU VID Special Add: Auto
DRAM Voltage Control: 2.23
SB 1.05V Voltage: 1.07v
SB Core/CPU PLL Voltage: 1.55v
NB Core Voltage: 1.41
CPU VTT Voltage: 1.35
Vcore Droop Control: Disabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: enabled
x CPU GTL1/3 REF Volt: 93
x CPU GTL 0/2 REF Volt: 93
x North Bridge GTL REF Volt: 97
DRAM Timing
- Enhance Data transmitting: fast
- Enhance Addressing: fast
- Channel 1 CLK fine delay: more agressive
- Channel 2 CLK fine delay: more agressive
CAS Latency Time (tCL): 5
RAS# to CAS# Delay (tRCD): 4
RAS# Precharge (tRP): 4
Precharge Delay (tRAS): 10
All Precharge to Act: 4
REF to ACT Delay (tRFC): 23
Performance Level: 6
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): 11
Rank Write to Read (tWTR): 10
ACT to ACT Delay (tRRD): 2
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): 5
Ranks Read to Read (tRDRD): 5
Ranks Write to Read (tWRRD): 5
Read CAS# Precharge (tRTP):4
ALL PRE to Refresh: 4
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
