Originally Posted by AndreYang
...what bugs?
Is all combos indicates values?
Don't apply if a combo is empty
...what bugs?
Hmmm not working with my MSI P965 Neo-F.
Timing's in bios : 4-4-4-12, change in tweaker too 4-3-3-8 and efect is 10-5-5-20 :eek:
...I send you a pm.
I reply to You ;)Quote:
Originally Posted by FELIX
Bug is only when i overclocking memory, in stoc clock's is ok.
Great work Felix, thanks so much!!
Hi Felix..thanx for this nice prog...
Just one question: what the difference between "Write to Read Delay" and "Write-Read Turnaround clocks" settings?
I come from A64 where we have only Twtr and "Read-Write Turnaround clocks",
so i really don't understand this "Write-Read Turnaround clocks" setting.
Thank you.
Gonna put this to use right away! Thanks a bunch M8.Quote:
Great program! I am now able to run PAT technology on my mobo ASUS P4C800 Deluxe with 4 moduls of ram and ofc my score in memory bandwidth increase over 6GB/s, before 5.8GB/s (sandra)!
THX:banana:
The version 2.2 (beta) is an instant freeze of the system on my dell xps m1710 laptop.
(micron ddr2 667mhz 5-5-5-15, intel 945pm chipset)
If I change it to 4-4-4-12 its a freeze. (might be a to big change)
Whenever I change one value its a freeze.
Both channels get the same value.
Might be that the ram cant handle any changes but if it might be a user error plz tell me :)
Anyone else tryed this on his m1710
...is the version 2.1 work fine on your laptop?
I send you a pm.
Attachment 50299
I have P5B Deluxe Wifi, just a quick question about the red circled box, is that a correct value ? Ask this because CPUZ is reporting Rev. C1.
Anyway, thank you very much for your effort developing this tool ! :thumbsup:
Yes i am still having the same error. After exit and re-open, the values in the box gone.... CPU-Z bug :(
->bing:I don't know if your stepping is C1 or C2,but I modified the reading,
try with this version:
MemSet22beta.zip
Has anyone had any luck getting this to work with Windows x64?
Hi Felix,
Thanks, its now showing C1.
Actually I was curious since P965 stepping C2 supposed to be release to manucfacturer by this Sept. :p:
But it is clear now, and again just guessing that your update was referring to this page below right ?
Intel® 965 Express Chipset Family Specification Update
For the Intel® 82Q965, 82Q963, 82G965 Graphics and Memory Controller Hub (GMCH)and Intel® 82P965 Memory Controller Hub (MCH)
Again, thank you so much ! Great Work you've done there ! :worship:
...before the update I was referring to this datasheet too,
but I made the reading on bit[0] offset E4,whereas it's bit[3] :D
are you having problems with Gigabyte DS4?
Hi Felix,
My motherboard is 915G with ddr2 533 4-4-4-12, i can modify all main parameter except CL --- the most important parameter (now i working at 4-3-2-4), i have tried all version of memset but none of them can change CL. i'm very confident that my ddr2 can work at CL3, pls help me.
Tks & B.rgds
Do these settings appear right for standard 5-5-5-15? The 42T for tRFC seems a big high or is that usual?
CAS# Latency (CL) - 5T
RAS# to CAS# (tRCD) - 5T
RAS# Precharge (tRP) - 5T
Cycle Time (tRAS) - 15T
Row Refresh Cycle Time (tRFC) -42T
RAS to RAS Delay (tRRD) - 3T
Read to Write Delay (tRTW) - 8T
Write to Read Delay (tWTR) - 5T
Weonline-> it's seem that it's practically impossible to changing Cas# with DDR2,
and I don't know Why...
Therat-> 42T is a normal value for 5.5.5.15 timings.
great. thanksQuote:
I have 2 sticks of kingston and 2 sticks of g.skill and this is the error I get when using all 4 sticks at once.
http://star.walagata.com/w/fetuskiller/memset.JPG
I get this same exact error with my setup if i try to set timings tighter then 4449 on my 2x1GB G.skill HZ. My computer runs fine, but for some reason i can't get tighter then 4449Quote:
Originally Posted by epox4life
Setting tighter timings in bios still shows 4449 in memset and cpuz
->epox4life,BottomUp:I send you a PM...
Hi Felix, thank you for what seems an interesting program. However I went to install it, into its own directory and thus folder and I get this message saying
"The driver TVicport can not be found"
Others seem to be able to get it running, but I don't know what is up with this.
My motherboard is the one in my signature. :)
