1.550/2.086/2.086/1.500
got it 3Dm. and ATItools stable in 740/814.5. Watercooled
Get some new stuffs soon and will Build some heatsinks for the vg.
Hope it get more stable then.
1.525/2.2/2.2/1.5 Stable at 750/872 with no artifacts using ATI Tool.
1.45/2.15/2.15/1.486 24/7 stable at 725/850 using ATI Tool.
Ok i just got my HIS x1900xt. I got ATi tool, i tried ending both ati services, but one will not end. Any ideas?
you should only have to disable the ati hotkey poller in administrative services.
Can u send me your bios? Please! ;)Quote:
Originally Posted by Elfear
Cant understand one thing, when i go to 814,5 and test, no artifact, lower volts, no artifacts, go upp again, trying 819, artifacts, go down to 814, artifats, go down more to 805, artifacts. :S
thats strange. :slap:
Looks like we have very similiar setups. Let me know how I can get the bios and I'll send it to you. Just pm me so we don't clog up this thread any more.Quote:
Originally Posted by licken
NM, got 25b now it works. But how do i get it clock in 3d mode?
guys, can you guys include FAN SPEED/COOLING TYPE too as part of the database? so we can see if cooling is the main factor or voltage...
thanks!
GOOD LORD!! my voltage red ships are @ 68C !!! Thtas bad right??? i've got some homemade copper sinks on the big black boxes and a 60mm fan right on them.
1.47/2.171/2.124/1.514
clocks @ 720/860 Air, no artifacts
Need water for the core, anything past 725Mhz locks up. Has to be heat. Highest vgpu tried is 1.495.
1.575/2.151/2.151/1.580
790 Mhz / 830 Mhz
HIS X1900XT
Watercooling (Silverprop) on core
OCZ Ramsinks on mem
Core - 47'C max load
Mem - 43'C max load
Vreg - 97'C :stick:
Vreg @ 97C!??!?
/me dies.
gonna put a fan over the card?
well heres my rsults so far.
HIS x1900xt
voltages 1.575/2.086/2086/1.53
732 core / 800 mem.
gpu- 39/48C on homemade water block
mem- Swiftech ram sinks and 80mm fan - HOT
vreg - stock almn piece + 5 copper homemade heatsinks + 80mm fan - 58C
im severly cpu lmited at the moment as well. @ 732 core vs 650 core, there is only 450 pt differnence in 3dm 05. my x2 3800 @ 2.5 just isn't going to cut it. 10400 v 10950, so its back down to 650/800.
Well thinking it about it.. its either cpu limited... or it may be becasue i have the card in a sinlge 8x pci-e slot....hmm.... Also from stock to 650/750, i gained about 1400 pts...
EDIT : 702/801 1.45/2.0/2.0/1.45
43 idle/47 load , 40 ambient
vreg 54C.
Im most upset as well becuase i can't turn everything up on FEAR. Im starting to think about getting a operton 170, amybe i can't push it to 3.0 on pelt.
jes compare 06 results then :) (minus the cpu tests)
What is you guys singlecore/XT results? (or am I the only one thats still running singlecore?)
http://service.futuremark.com/compare?3dm06=139874 5990 06
http://service.futuremark.com/compare?3dm05=1841836 13200 05
http://service.futuremark.com/compare?2k1=8903303 39.7k 01se
Card @ 750/875 (880 for 01se)
Voltages: 1.575/2.113/2.086/1.503
I am, and a slow one too.
I just got mine and realised that it runs so damn hot. Does anyone think it runs hot enough to run it 24/7 with a vapochill ls on it?
Originally Posted by LenniZ
Here are mine with Opteron @ 3.07Ghz and gfx @ 790 / 830:
http://service.futuremark.com/compare?3dm06=168287 6087 '06
http://service.futuremark.com/compare?3dm05=1856355 13447 '05
http://service.futuremark.com/compare?2k3=4660787 22221 '03
http://service.futuremark.com/compare?2k1=8916729 40484 '01
(Silverprop on the core, OCZ ramsinks on the mem). I think I have 1.1ns mem too (from looking on the chips before the ramsinks went on).
The best i have been able to get so far has been 12412http://service.futuremark.com/compare?3dm05=1834943
This was at 685/778. Upping to 702/814 did nothing for me. I guess this would be where the cpu limitation comes in. Opteron 148@ 2.9.
Powercooler X1900XTX - Stock
725/820
1.5/2.1/2.1/1.5
My scores are in my sig, not too bad for s754. :)
I can bench the cpu at 729mhz, but anything over that and it crashes. I can bench the ram at 840mhz but it doesn't seem to help my benchies.
I found my core clocks higher when I leave the 2nd voltage on default.
I thought I was limited to ~735 on the core, but keeping the VDDCI on default, I was able to clock it up to ~760 :D
I have a gecube x1900xtx I have no issues to 815/900 1.5v and 2.130v but the sucker runs on the warm side no artefacts but the core wont go not 1 mhz more no mater what i do I think this due to power runs 14779 in 05
Hey guys, help me get my X1900XTX run better... I mean im really not happy... only 760\882. I see cores reaching 790s. Im using watercooling. Innovatek G70 lol... the memory wont get any cooling but the gpu does.
With new 6.3 drivers i could do 14,000p in 3DMark2005. Single Core sucks :(
I but my rig on the balcony. It was like +5c outside.
Maybe someone could give me a good BIOS?
AMD64 Opteron 148 (SingleCore) 3201MHz
Club3D ATI Radeon X1900XTX default Core: 650MHz\Memory: 725MHz
2x256Mb PC3500 Corsair 266MHz 2-2-2-5
DFI Lanparty SLI-DR Expert
12,575p http://www.zone.ee/wrc2006/1/X1900XTX_default.JPG
Overclocked:
AMD64 Opteron 148 (SingleCore) 3239MHz
Club3D ATI Radeon X1900XTX @ Core: 760MHz\Memory: 882MHz
2x256Mb PC3500 Corsair 269MHz 2-2-2-2
13,988p http://service.futuremark.com/compare?3dm05=1856576
1.520\2.2 or 2.3 or 2.4 showd artifacts. 2.2 sometimes worked... i mean this ATI Tool is pure crap. Gonna hardmodd the card
You can overclock much better by NOT showing the 3D spinning cube.Quote:
Originally Posted by PlatoonSgtElias
Set clocks, show cube to see if they have worked.
Close cube, set clocks a little higher.
Repeat.
I'm now on 790 core / 830 mem with an XT.
yes, except not really, atleast not for me. i got an extra 20 mhz on the core and 20 on mem by doing that, but then FEAR froze while in the menu. so i backed downQuote:
Originally Posted by Jimbo Mahoney
