first run..
http://www.bfroe.com/superpimod.JPG
first run..
I am having an issue with superpi mod and I don't know were to ask it so I will just ask it here.
When my e6600 is clocked at 3600mhz in vista 64 the program stops working and reports this:
APPCRASH
Application Name: super_pi_mod.exe
Application Version: 0.0.0.0
Application Timestamp: 624c1f35
Fault Module Name: StackHash_75cc
Fault Module Version: 0.0.0.0
Fault Module Timestamp: 00000000
Exception Code: c0000005
Exception Offset: 3fffffff
OS Version: 6.0.6000.2.0.0.256.1
Locale ID: 1033
Additional Information 1: 75cc
Additional Information 2: 2419b6ea3c5d39ffac9575d4d53aeee6
Additional Information 3: a255
Additional Information 4: 83da4b4ca49b738b489e75545f1cdf05
The overclock is stable as far as I can tell, 9hrs+ Orthos small FFT priority 9 and runs superpi non mod 32m flawlessly. What am I doing wrong? does it think I am cheating. Is their any difference between superpi and pi mod that would stress the memory differently?
I can't finish 32M in Vista either, even on stock specs. I runs every other bench fine. Is this a Vista error, SuperPi or my PC?
no problems in running superpi mod 1.5 here under vista x64
Maybe it's something to do with p965 chipset and vista? Its weird because it doesn't give a not exact in round like it would if their was an instability. It just says application has stopped or something like that. Maybe the Mod considers something the p965 is doing a cheat. This is interesting, So can you guys with problems run superpi non mod just fine?
Crashes for me as well in Windows Vista X64 Business Edition. It says application has stopped working and sometimes I can get a successful run in 1M however most of the time it just crashes :(
me too , i think its P965 chipset in vista
I've got exactly same error. My thread about that is here:
http://www.xtremesystems.org/forums/...d.php?t=154295
has the bug been confirmed??
that 32m test wont complete under p965 chipsets in windows vista?
i had the same problem BOTH with p5b deluxe + p5k in vista 64
mee too...vista 64 cant finish 32mb super Pi... :(
Guys
I think I've found what's causing these errors.
I've got solution which is far from being perfect.
Please try turning off Audio services in Vista ( start> run> services.msc, find Windows Audio on the list , double click and stop it ).
After this run Super PI and please post the result here.
That did not work for me, It was worth a shot though thanks.
In my case SuperPI exit even on stock speed/voltage. Is yours as well ?
If not maybe OC is the reason. Otherwise try to boot up into Safe Mod and run SuperPI. If it will work this time it means its something in your system.
I had Audigy sound driver causing it. My "Windows Audio" service is on now while driver isn't installed and SuperPI works fine.
Last step for me is to find properly working driver.
To those who wants to disable sound just for SuperPI and then quickly turn it on. Create two .bat files on the desktop
SoundOff.bat:
net stop "AudioSrv"
and
SoundOn.bat:
net start "AudioSrv"
Viola
Where I can download this nowadays? xtremesystems.com seems to be unresponding. :(
Never ever format your harddrives without taking copies of benchmarking stuff...
Q6600 2400@3734MHz, 1.529v, TT Big Typ 120VX
ASUS P5B DLX, BIOS v.1215
3Gb DDR-2, 333@415MHz, 5-5-5-15 2T
SuperPi mod1.5 XS, 1M = 13.984
http://ipicture.ru/uploads/080131/thumbs/2q6V1SuTGl.jpg
Gigabyte 965P-S3
Intel Core2Duo E6700@3,8Ghz
2×1GB/760 (4-4-4-6) Micron D9DQW
SuperPi: 13,532
I guys, i'm aving some problems with superpi-mod.
Running 32M i get not-exact in round. The system gives no error with original super-pi (either running 4 threads togheter) and any other testing programs.
Only superpi-mod gives me problems, any explanation?
My system:
Asus p5w dh deluxe + q6600 + 4gb ram + 1TByte raid hd + x1900xt + Enermax elt500awt + Windows XP Pro X64.
Thanx ;)
I'm using Vista Ultimate SP1 and always having error/failed when running 32m even in stock settings. Help me please! :(
Bit of a thread revival, same problem here on Vista x64 SP1, and for the loops that do pass I'm failing the validation. Funnily enough 1.4 works fine, and so does the original 1.1e
