Don't know what you are on about but performance of Zacate in its segment which is targeting net-books below 500$ is more than enough and any day better than Atom.
SB IGP is not a revelation by any means since it will be humillated by the 400-480SP monster that is Llano(and not bottlenecked by low frequency cpu's, 2.5Ghz+ dual/quad setups). They just showed their IGP performance earlier, just that.
At mínimum 2-3 times faster than fully enabled SB IGP.
Zacate seems pretty balanced i mean a 500mhz 80 shader gpu with a dual core cpu that can do 90% of Athlon II performance running on 1.6Ghz is good but then the 1Ghz Ontario part with most likely lower GPU speed and performance is a eye sore.
I hope tablets are released with the Zacate avatar and not Ontario because there are things online that 1Ghz dual core Athlon II cant deal with properly. There have been kinda tablets based on CULV's before so its not a far fetched idea, then again Ontario is a 9W part and Zacate a 18W part.
it was ontario that was playing avp right? i thought it was the same as zacate only lower powered?
i know llano will be faster(spec wise at least), but it will also be later by at least a quarter. SB will be the first ondie gpu that will be better than the low standalone graphic cards. (we don't know what anand tested, he isn't sure either. But what he tested was slightly better than the 5450.
edit: the test was done on the Zacate. But we have no clue about the clockspeeds that it was running (some rumours) and we don't know the launchspeeds of ontario or Zacate. They can also trade more gpu for cpu or toy with such settings on the fly. As Anandtech mentionned gpu clock speeds are not written into stone and the drivers were not optimized yet, so there is enough still in the air for us to be suprised at launch (or the reverse ofcourse).
Tomorrow I'll do a test with my AII @1.6Ghz and disable 2 cores for the batman run.
Is that scene at the beginning?
That logic is flawed.Because you are comparing a NETBOOK 18W platform, with a desktop GODKNOWSHOWMANY watts platform.
And they`ve put this decent GFX ondie, because thats the thing netbooks lack ATM (besides slow ass in order cpu).
Remember that there are many different loads, many of which require GFX computation power more than CPU ones.
My point is, a multi billion dollar company (AMD) probably knows better what they put and most importantly WHY into their NETBOOK chip.
Actually no, if you look around most people where suprised how it performed, no pre hype no nothing. Most people focused on CPU performance for SB and its still the main focus.
For amds fusion lineup on the other hand everyone had gone nuts about the APU starting back then with the AVP demo. Yet the first numbers we got where released just now and without the screwup on the side of amd we wouldn't even had any B:AA numbers.
Anyway thats not my main point, what I meant with 780G hype was that people only focused on the "superb" IGP performance, but basically that changed nothing on the adoption, despite having 2x or even 3x the performance of a G35 back then.
Gaming gets way to hyped, epsecial for the intented platform.
Imho the most important factor: Power Consumption, Video(HD) acceleration, Webacceleration in that order. Gaming is nice to have but absolutely not neccecary.
i think ive seen this movie,and it was sooo lame.just like what you guys do to every AMD/Intel thread
the 4 AMD gang members are leaning against the wall,when 4 intel gang members walk up the street
"the rumble music starts" the amd gang starts walking towards the intel gang,because they have no right
to be here.as they walk toward them,they lean slightly forward and begin snapping their fingers to the
music,and then the perfectly executed choreography begins,and the comical dance punches are thrown
its going to get ugly,and i dont mean the fighting i mean the ugly ridiculousness of the whole thing.
(switch it around for intel threads)
the snapping, dancing gangsters
always the same guys that ruin these threads for us .thanks
there are always people that are never going to be satisfied...
AMD should have compared Zacate to any intel CULV Arrandale part (18W)...when AMD would have said 10X the performance on the grafic side...maybe some guys here would have been happy...:rofl:
But AMD is a decent company...the went with a mainstream 35w Arrandale CPU...:ROTF:
for the size zacate is...and the grafic implemantation and whats doing grafic wise, it's a big plus to AMD :up:, if you can not recognized that...then dear Fan boy..get out of this thread...
when LLano shows up...same story...Sandy Bridge is going to rely on Nvidia type Optimus platform(more power consumption) if it can, to compete with LLano GPU...
AMD APUs are going to change things in the market, especially Ontario...;)
I dont think anyone verified this, but, Ontario and zacate are basically the same thing arent they ?
Which means, us overclockers could turn low end ontario chip into zacate with a push of a button :).
Would be a nice option to have when power isnt the issue.
well at least this platform will be able to deliver this video performance within a low power and low cost design. Intel is already adding/changing SB roadmap to counter this.
And there was nothing wrong with 780 after the initial 690 trial, this was finally a chipset that was able to deliver htpc needs, far far away from what Intel was able to deliver - or lets say not able to provide for just not even aero on an OS level :D
I found this about Llano:
http://white-rabbit50.at.webry.info/...article_1.htmlQuote:
・Llano
4コア版
95W:3.6GHz+480sp(HD5570より上)
60W:3.0GHz+480sp(HD5570位)
45W:2.6GHz+400sp(HD5550位)
2コア版
75W:3.8GHz+240sp(HD5550位)
65W:3.4GHz+240sp
35W:3.0GHz+160sp(HD5530位)
20W:2.6GHz+160sp
If true 32nm looks to be helping out AMD in a big way thats more than half the tdp of Athlon II 620(4core 2.6ghz)Quote:
4 core 45W:2.6GHz+400sp(HD5550位)
Following that BD may have some very high clocks.
EDIT: Or is Llano 40nm??
Yes, until Q4 when Athlon II X2 270 3.4Ghz 65w appears.
slaveondope
Llano is 32nm being done by GloFo. Ontario and Zacate by TMSC wich I think will have a refresh by Q4 2011 / Q1 2012 using their 28nm process, unless TSMC fail at execution again xD.
It's common knowledge that AMD squeeze more out of their nm shrinks than intel specially for power consumption (x4 955 --> x6 1090T same 45nm, even less power with the same tdp / i7 975 45nm --> i7 980X 32nm).
The 620 95w TDP is just fictional. We also have the 615e 2.5Ghz 45w.
If these are base clocks without turbo things will get very interesting shortly with both AMD and Intel seemingly releasing very good products :D:up:
How reliable is that source?
**Edit The Ontario TDPs and clocks on the same page are different from the ones already announced
If those identifications are correct, the compititor for ULVC is llano and zacate 18W will be more or less obsolete. If this is true for that process, ontario/zacate really need to go to those fabs as soon as possible because TSMC 40nm sucks compared to that 32nm process.
Edit: the previous numbers of ontario were hokum, these probably also.Quote:
・Llano
2
20W:2.6GHz+160sp
・Ontario
18W:2.2GHz+80sp(HD5450位)
I really hope that those dualcores are native dualcores with only 240SP physical. That would make them cheap.
But I am confused. Llano seems to beat Phenom II in performance despite built in GPU. Bulldozer must have a considerable performance advantage to be justified. Could mean a very nice 2011. :)
