with or without the shutdowns?
where do you guys all get the beta bios/
ASRock support via eMail...
PS - 1.80 is out...
http://www.asrock.com/mb/download.as...xtreme3&o=BIOS
Need 1.91A... :up:
PS - No more options to chose fullscreen logo,
but an advanced Turbo UCC option...
And they changed the CACC options... Now You can turn off the core You want wery easy.
http://i39.tinypic.com/10zy00h.jpg
http://i41.tinypic.com/21acs43.jpg
maybe once i really start overclocking i;'ll have to hit one of you guys up to figure out which bios is the best for it.
Back to 1.53...
1.80 is buggy...
1. It doesnt work with my Mushkin 2x2GB 1600 CL9-9-9-24 RAM.
2. The System stops responding every 3-4 hour, God knows why.
1.53 best so far...
ASrock Extreme 3 won the Hwbot IGP contest, we never imagined it would be possible on what they call a budget brand :p Plus we did an IGP WR on 3Dmark03 and 05 loooooooooool
I'm still myself on 1.2 bios with the 965 and 8Gb of Corsair 1600C8 rams (Thx Rol-Co for that bios)... does all I need... just need to retest the 1090T on the newer biosses...
memory QVL doesn't list OCZ gold 1600c8 lv (OCZ3G1600LV4GK). does that matter?
no you should be fine with that
Well... 1.80 is realy not good bios for me...
Much problem with GPU's, CPU's and RAM...
Mushkin won't work at all...
Witch 1.53 the board works the best for me...
ordered the 880G version, great price for all the features it offers.
the 880G Extreme3 bios page on asrock.com lists the 1.20 version. the boards are identical sans the IGP clocks, so i wonder if this bios is any different from the 890GX. when matching the release dates, the 1.20 (880G) might be the 1.60 (890GX). i'll let you guys know.
new user of this fantastic board...juz got it from newegg last thursday...works well with my crucial ballistix blue tracers :D
congratz hpv500 .......realy nice board.
1.8 bios works fawless here, no problems found yet.
I have AHCI enabled but can't see Safely Remove Hardware icon. Disks connected on eSata supporting AHCI and NCQ are recognized but I can't find a safe way to disconnect them, I can just go into diskmgmt.msc and put them "offline".
Driver is "amd ahci compatible raid controller".
The are plug&play, dont break Your head. :)
...the FX version is available now here in HK since last week i think
Ordered the ASRock 890FX Deluxe3 from NewEgg yesterday.
Long-time Asus user here. 1st time trying out ASRock. Hope it doesn't disappoint ...
I hope it as good as the GX model... good luck, report back plz
Just have X2 555BE batch 1008EPMW. But it can't unlock. So this is my setting for daily. But why default vcore different with another X2 555BE?? My X2 555BE 1,36v on bios. But I have another X2 555BE (same batch) 1,135v.
http://img294.imageshack.us/img294/3066/4ghzd.jpg
The 3 is a pretty sweet board. Glad i went for it over the much more expensive asus
Does any of you guys have problem with blue slots? I tried them with different memory but no boot, only with white ones...
And cpu-z acts weird, it shows different frequency than real one, lower for few seconds, normal for few seconds, higher fo few seconds and so on in circles
http://img685.imageshack.us/img685/4162/4350oc.jpg
