and may you tell me will it be possible to put two 3x120 rads on bottom with16cm psu?
Love this project, totally inspiring to me! Question, would a 140.3 fit inside the case across the top? I'm debating a single loop w/a 140.3 and a 120.1 for an i7 920 and 2x GF100's.
mlee49: I've seen few worklogs with 140.3 on top. Sorry, i'm too lazy to search urls for them. Main thing you should watch for if 140.3 rad's width fits between 5.25 enclosure bays walls. Some 140rads fits (don't remember, XSPC or TFC or something else), some (in particular wider Black Ice GTX/SR1 - do not = required some cutting of top of those 5.25 walls). And of course you need cut top for larger rad and paint cuts or slap some nice rad grill ontop.
have this case and think about it right now so theres 1cm gap only (with RX360 and OCZ PSU)and in this place bunch of wires ATX24 connector. If you can mod your psu - (turn this bunch on 90degrees) I think it possible.
noeru you have this PSU what do you think is it possible put here RX360?
http://www.overclock3d.net/gfx/artic...155701257l.jpg
http://www.overclock3d.net/gfx/artic...155703682l.jpg
also for two rads at bottom you'll need this side panel
https://shop.corsair.com/store/item_...spx?id=1171683
Nice build and photo's. But I think the one color light would look better.
Hi 00011011
980X I tried two, we needed first 4.3G Vcore1.65V:shakes:
I tested the CPU and heat test operator prim95 I think highly reliable utility.
1core will not even when I make an error. And one 12-hour loop
Required.;)
Thanks Gonzalo-Gonads
Large individual differences in the CPU! It is too many bad yield Bath #
Hello The.Sorrow:)
Bitospawer GT295 combines the connection of the joint:up:
Attachment 103773
http://www.performance-pcs.com/catal...ducts_id=24677
http://www.performance-pcs.com/catal...ducts_id=23697
Hello rioja:)
What unit two loops? Not that my 120x3
One of the right panel, the second left panel, attach the three intermediate panel.
However, air flow is difficult.:confused:
the top exhaust:yepp:
Hello mlee49
Thanks to word of praise!:)
It is a difficult debate! I see skinnee test.
XSPC rad I like the pitch. Slow (800-1000rpm) of the cooling fan is working I prefer quiet.
For the GTX480, HWLabs SR1-480, XSPC-RX480 candidates cited a quietly cool for me to determine the size needed GTX 480 has a narrow pitch fan speed 1800rpm ↑ SR-1 is a low volume.We have to xspc480.I think I prefer a quiet 140.3.:rolleyes:
Hello Nage
I tried to put a 360 in the first study.
But I abandoned the ocz-z-z1000PSU
360 if possible get things set up next to the wiring is possible.
But now my system is 1000W but I have trouble in getting enough.
It will create a new side panels and me.
Hello Awers
Thank you Yes! Certainly:D
Thanks ScottALot She is so very cute:p:
amazing build ... I picked up few things and replicating it in my current project LINK
I'm struggling to fit the XSPC Dual bay res in the 5.25" as the sliders are sticking too much and prevent me from putting it in. I might have to dremel them off.
I appreciate your response noeru, but you didn't answer my question; perhaps you didn't understand me. Hopefully this Google translation works properly :)
明らかに良い、低いがあなたの意見(または他の誰これを答えることができる?)どのようなあなたが安全な2 4 / 7オーバークロック(安定仮定を感じると、最高のコアタンを検討する)?
現在、私は@ 4.3 GHzのです。私はまだすべての夜間テストを実行していない10分小さなFFTの後、私の一番ホットなシン グルコアの温度を77でいくつかの点で大変疲れてテストを拷問が、平均全6を実行して72です 。
00011011
sorry Google's translation :p:
Overclocking 24 / 7 try Prim95 4.5G 12hr 1roop roomtemp is 22.5
maxcore temp core1 69 core2 71 core3 63 core4 66 core5 69 core6 68
C1E off HT on 144.7x31 Vcore1.400v QPIVTT 1.350v NB 1.42 DRAM 1.63+
Attachment 103922
I tried 4 Gulftown results
Gulftown is very large individual differences.
4.3G but passes Vcore1.65v batch # There were no:shrug:
http://noeru-dairu.jugem.jp/?page=1
next VGA is :rolleyes:
Attachment 103923
I get worried about the next VGA:confused:
GTX480 2GPS VS HD5970 4GPU
Definitely the 5970s.
ScottALot、Saltire Thank you
GTX480 is 438w:eek: HD5970 is 399w:clap: GTX295 is 418w
SLI and CF really does make a difference seems
I wonder if you can get these: http://www.newegg.com/Product/Produc...-460-_-Product
Cant believe this one slipped by me for so long. I just spent the last hour reviewing this thread. Absolutely awesome. Good work, noeru.:up:
Is it just me, or is the nickel coming off of the Mips Ramfreezer in post 211? :eek:
Can somebody please tell me what this tool is?
http://www.xtremesystems.org/forums/...1&d=1258769951
I'm about to drill out the front rivets but didn't see this additional tool that's needed inside the bay.
That's a Black & Decker RTX flexi shaft.
http://www.blackanddecker.com/Produc...ProductID=2709
Phil
Thank you much Phil!
Great work so far Noeru. Your build is the inspiration for my future 800D build which will look very similar to yours except I have only (1) 240 radiator on the bottom and (1) 360 radiator hanging off the back of the case.
Attachment 104175
Hello Danger30Q
It is as you say Philwong:)
hello and thanks Philwong :up:
Attachment 104177
GTX480 vote has been also extended
Which do GTX480SLI vs 5970CFX Haisukoa?
I want to order 480 or 5970 Waterblock soon:(
The performance-pcs
Thank you for those additional pics noeru.
thanks All. I will try to hd5970. i like 4GPU:p:
Attachment 104376
Attachment 104377
Attachment 104378
