Geforce 4, 6 and 7 and 8 series all offered near doubled performance, as did the original Radeon, the 9 series and the 4 series.
I think power consumption may still be up in the air. Cypress is only supposed to require one PCI-E power connector, right?
i was really happy with how well the 4870 did for its chip size, i think they may be going larger simply to have single chip solution that may still rival all competition, but hopefully keep with their small cores at a great price that worked so well for the 4000s
Except that 1.5* previous gen would surpass Moore's law of doubling the performance every 24 months (it would result in 2.25x the inital performance every 24 months).
If we assume the new generations of card are coming out every year, and that they respect Moore's law of transistor density (and that transistor count equals performance), then the performance would be
nextgen = sqrt(2) * previous gen
or roughly nextgen = 1.41 * previous gen
Just sayin' ...... ;) (sorry about being anal)
its honestly tough to compare across generations when there is a major change in how things are handled, ie DX versions. if we look at just a framerate change, it may be totally different from the changes in furmark rendering.
there is however a different way to look at it, which it overly simplified. the real changes only occur with new processes, going from 55nm to 40nm etc. if there are any delays, then everything can be held back by months, and when expecting a new one every 24 months, 2 month delay is pretty massive in that formula.
looking at AMD, the 45mn quads came out at the beginning of this year, and intel is showing off a 32nm already. the performance jump per year for AMD has been quite sucky since their attempt to switch to 45nm, and they felt the pain of using 65nm for like what, 3 years?!?
so to end it, im not a big fan of trying to say one generation will be x more powerful than the previous. as there are only a few real things that go into it, and each of them can sway the numbers very easily.
To the guy who wanted the price on a 5890 x2 or w/e it will be called.
I'm gonna stay predictable and say it will be the same as a 4870 x2 so around 600.
I say their main stream card (read: 5890) will be around 300-350. The 5850 (read: 4850 equivalent) will probably be around 200-250. The rest...I don't care about.
So the USS Hornet is where AMD is going to launch Evergreen from from. Very interesting and very original.. :)
They might be planning on dropping down some cards with attached bombs on Nvidia headquarters... "World Card War I" ??... **runs and hides in the basement with a tin foil hat*
http://www.jessicadunton.com/blog/TinfoilHat.jpg
http://vimeo.com/6182068
r8xx in action dirt 2
That is a good video... :cool:
Forget all the DX11 haters... I can't wait to see DiRT2 in DX11 !!
Stolen from neliz- (who really wants to reg at chiphell?)
http://tweakers.net/ext/f/Ut6Fka0lrP...qdkjZ/full.jpg
http://tweakers.net/ext/f/ZzgihFdMod...0LuGS/full.jpg
http://tweakers.net/ext/f/49feNT8Y4a...tuLUb/full.jpg
4770 "reference" cooler being put to good use.
Estimated to be between a 4870/4890 performance for a "current" 4850 price.
VRam chips on both sides... Does it mean it's 2gb? Or is the PCB just too short?
