PL7?? how about PL6??
http://i287.photobucket.com/albums/l...l1/1066CL4.jpg
[QUOTE=Chri$ch;3129696]Got my Board today :)
http://www.abload.de/img/dscf7705vrn.jpg
is that a demo board??
cause all the retail ones comes with fujitsu caps.. afaik.. full red..
ures mix..with ncc
mine is like this
http://i95.photobucket.com/albums/l1...ge101Small.jpg
http://forum.lowyat.net/index.php?sh...ost&p=18417293
Wow! Please, gimme Everest results!
Unbelievable! Just imagine, what will can do my RED DEVIL sitting on M2F ! :) :)
later dude after the orthos run..
but i want to ask everbody here is ure board like mine or like chrish?? the caps..
so far theres 3 kinds of maximus 2 formula
1. reds+blue+purple at the bottom
2. reds +purple at the bottom
3. full reds
reds are fujitsu RE's
Blues are NCC what i was told
purple??
This is mine:
http://www.abload.de/img/img_0001xfq.jpg
I´am not able to test the max. FSB, because my little E2160 makes only 400 Mhz FSB :(
But in a few weeks a new CPU is coming :D
What are your NB Temps., I think they can not be right, because the NB Cooler is cool, only 32,6 Grad Celsius
24/7 Settings:
http://www.abload.de/thumb/prime3613x13.jpg
running two hd4870's inside the case.. at stock settings.. fan etc..
hmm u have a one blue caps..
I have found this board is very very picky on voltage settings. Ican run OCCT and Prime95 for days. play a 3dgame POOF Black Screen
also interesting.. seawolf and u are from germany..
should have come in the same shipment.. unless this boards are selling like hot cakes..
but different caps..
is the sound card on this board limited to only the top slot black x1 pci-e slot or can you put it in the white slots also?
is here someone who get 530FSB (+) stable on this board?
Im waiting for my one:) I hope that it will be much better than my abit quad gt x38 wich is shi**.
Christ I can't get this board to to pass Test#3 on memtest86 with either Corsair Dominator PC8500 or OCZ Platinum PC8500. 2 sticks or 4 sticks. Even at all stock Auto settings other than mem voltage it still errors out. Asus just tells me to make sure my RAM is compatible and I know this RAM is good as it passes in other systems. WTF? I have the worst luck with boards. I guess I will have to RMA this board too. I already had a GA-EP45-DQ6 that had broken SATA ports. Now this. I swear.
Can anyone confirm they have this board working well with OCZ Plat or Corsair Dominator?
Dont use Auto Setting for RAM Volt, Manual set.. I cant run Stock anything on this board. I have to Manual enter all Voltages
I can go from 1.31 VTT to 1.32VTT and my system will get into windows, Very icky on setting
I am using Gskill pc8800 Bios 0701 Helps when u get the setting Correct
maybe you got a lemon x2beach? got it to 450*8 with my q6700 everything else on auto but the core and ddr2 voltage
this is for the power :D
because that thing (Republic of Gamer's chip) is lightning, when power is on...
No matter what I do I cannot get Games Stable. At Stock speeds,
I ran memtest for 30 loops no errors
Ive tried ATI 4870, GTX 280 Video Card Both New Vista 64 installs
but I can Run OCCT and Prime 95 for 12hrs with no errors
Again I am trying to Run my Q9550 At Stock
What else can it be?
