Finally got around to taking backside photos of my card which has a blue PCB. Any ideas where to measure GPU and Mem volts ?
All photos at http://i4memory.com/reviewimages/vid...CEQ3/backside/
same board just different color.
[IMG]http://img104.imageshack.us/img104/2...ceq3003un0.jpg[/IMG]
Thanks Jimmyz!
Bo fox, with regards to HIS HD3850 IceQ3 bios and this guide http://www.xtremesystems.org/forums/...8&postcount=35 which lines in bios you editing in hex editor ?
Using Hxden my HIS HD3850 IceQ3 bios is default 720/910
720mhz reverse hex = 401901
910mhz reverse hex = 786301
voltage next to these entries has reverse hex = BE04 = 1.214v
When i search for these values, there's 6 results. 1 entry at near top of file, and 5 entries grouped close together.
http://img184.imageshack.us/img184/9...inal720dz9.png
http://img295.imageshack.us/img295/7...inal920su1.png
EDIT: okay found what you changed using hexcmp2 compared to my bios
Code:Different between:
First file: "K:\Videocards\3850\mybios\original\his3850iceq3_bios\his_3850iceq3_original"
Second file: "K:\Videocards\3850\moddedbios\bofox\HIS3850_512MB_3870volt\HIS3850_512MB_3870volt.rom"
Shift: 0
Shift: 0
Shift: 0
00000020 | AE | 00000020 | BA |
00000050 | 39 | 00000050 | 38 |
00000058 | 30 33 32 36 | 00000058 | 32 30 33 39 |
00000060 | 32 | 00000060 | 37 |
00000098 | 34 | 00000098 | 35 |
000000C0 | 34 | 000000C0 | 35 |
000000F8 | 31 32 30 | 000000F8 | 38 33 35 |
00000140 | 4F 41 | 00000140 | 6F 6F |
00000148 | 45 41 45 | 00000148 | 6F 6F 6F |
00000150 | 45 4F | 00000150 | 6F 6F |
00000158 | 45 47 45 | 00000158 | 6F 6F 6F |
00000160 | 49 47 41 | 00000160 | 6F 6F 55 |
00000168 | 45 44 47 49 44 | 00000168 | 6F 6F 6F 6F 6F |
00000170 | 45 4F | 00000170 | 6F 6F |
00000178 | 4F 45 41 | 00000178 | 6F 6F 6F |
00000180 | 41 | 00000180 | 6F |
00000188 | 41 | 00000188 | 4F |
00000268 | BF 8C BB 0D | 00000268 | 61 46 BA 1C |
00000270 | 78 12 4A | 00000270 | 5A 6C 0A |
00000278 | CF 9F 57 DD 3F 07 E5 F4 | 00000278 | 07 88 CC 8A DC CD 01 4F |
00000280 | A3 CB 88 25 10 | 00000280 | E9 2E F4 54 1B |
0000AAE8 | 40 19 78 63 | 0000AAE8 | 80 1F 98 7F |
0000B7E0 | BE 04 | 0000B7E0 | 2F 05 |
0000B7F0 | F6 03 | 0000B7F0 | D9 04 |
0000B800 | F6 03 | 0000B800 | D9 04 |
0000B808 | 40 19 | 0000B808 | 80 1F |
0000B810 | 78 63 BE 04 | 0000B810 | 98 7F 2F 05 |
0000B820 | F6 03 | 0000B820 | D9 04 |
0000B830 | F6 03 | 0000B830 | D9 04 |
0000B838 | 40 19 | 0000B838 | 80 1F |
0000B840 | 78 63 BE 04 | 0000B840 | 98 7F 2F 05 |
0000B848 | 40 19 | 0000B848 | 80 1F |
0000B850 | 78 63 BE 04 | 0000B850 | 98 7F 2F 05 |
0000B858 | 40 19 | 0000B858 | 80 1F |
0000B860 | 78 63 BE 04 | 0000B860 | 98 7F 2F 05 |
0000B868 | 40 19 | 0000B868 | 80 1F |
0000B870 | 78 63 BE 04 | 0000B870 | 98 7F 2F 05 |
Thanks very useful info :)
Question do we need to edit 2D voltages for higher 3D clocks ? Or editing 3D voltages only is fine ?
I just edited my 512MB HIS HD3850 IceQ3 bios (dated 29/11/07) - changing 3D voltage to 1.327v and clocks from 720/910 to 736/982 and fixed checksum to original bios (7300).
Then compared it to Bo Fox's HIS HD3850 3870 Load bioz (dated 28/11/07) which had clocks set at 736/982 with 2D and 3D voltage changes.
Attached is winrar file with my bios and bo fox's along with the differences.txt file from hexcmp2.
http://img231.imageshack.us/img231/9...loadvsmdu8.png
Bioses http://fileshosts.com/videocards/HIS...50_bioskit.rar
Weird, tried flashing my bios and it flashed but when i go into windows rivatuner is blank and doesn't report a card at all .. flashed back to original bios for now.. anyone take a look at my bioses and see what i did wrong ?
When flashed the reported device id and new bios version are also blank for me ???
thanks
edit: flashed with Bo fox's HIS 3850 736/982 with 2D/3D volt modded and that worked fine clocking to 837/1098 for 3dmark05/06 :)
Thanks use this bios http://www.xtremesystems.org/forums/...3&postcount=90 after unsuccessfully editing my own HIS HD3850 IceQ3 Turbo bios and happy to say I've gained some ground :)
before
2x 512MB HIS HD3850 IceQ3 default 720/910 oc'd to 783/1098mhz CF via ATI CCC.
after
1st card does 837mhz GPU
2nd card does 824mhz GPU
haven't tested max mem yet past 1152Mhz.
Gunna freeze this card tonight, hopefully I can get past that 800mhz limit I had before, otherwise I know its a BIOS issue.
strange I still seem to be doing something wrong using hxden to edit my bioses ?
I tried editing bo fox's HIS HD3850 bios from 736/982 to 810/999
hexcmp3 differences
And still when using atiflash 3.49 when i flash to 810/999 version my bios version goes blank ??? flash back to bo fox's version and fine ??Code:Different between:
First file: "K:\Videocards\3850\mybios\modded\512MB_HIS_HD3850_bioskit\bofox\HIS3850_512MB_3870volt.rom"
Second file: "K:\Videocards\3850\mybios\modded\512MB_HIS_HD3850_bioskit\bofox_810999\HIS3850_512MB_810999.rom"
Shift: 0
Shift: 0
Shift: 0
0000AAE8 | 80 1F 98 7F | 0000AAE8 | 68 3C 3C 86 |
0000B808 | 80 1F | 0000B808 | 68 3C |
0000B810 | 98 7F | 0000B810 | 3C 86 |
0000B838 | 80 1F | 0000B838 | 68 3C |
0000B840 | 98 7F | 0000B840 | 3C 86 |
0000B848 | 80 1F | 0000B848 | 68 3C |
0000B850 | 98 7F | 0000B850 | 3C 86 |
0000B858 | 80 1F | 0000B858 | 68 3C |
0000B860 | 98 7F | 0000B860 | 3C 86 |
0000B868 | 80 1F | 0000B868 | 68 3C |
0000B870 | 98 7F | 0000B870 | 3C 86 |
attached bo fox's bios and my 810/999 and also 810/999 with same checksum as original 736/982 bios of 7500 (this one flashes with bios version intact but rivatuner shows blank device)
Stuck at 830 under dice, argh. I dunno if my card just clocks like crap or it is BIOS..
http://img223.imageshack.us/img223/4561/jan43du0.jpg
i tried bo_fox's bios with 3870 voltages, flash was good and i have now 2d/3d clocks working properly, overdrive also works but somehow my core still stuck at 763mhz :(
any ideas why i can't go over 763 mhz? the card iddles at 42ºC and full load peak is 63ºC...
with 3870 voltages my card should heat a bit more but it didn't happened, weird stuff...
another question: what's the best way to find max core? how do you guys do it?
thx in advance
edit: i double checked and overdrive doesn't work, not a big deal lol
GenTarkin
Can u post bios for HD 3850 256MB
385/ 925
thx a lot
Hey.
I just bought Gigabyte's HD3850 512MB with Zalman cooler.
My cards core went up to a stable 785 core and 900 mem @ 3D Mark06. Crysis crashed with those settings.
From Rivatuner i got this info:
$ffffffffff ----------------------------------------------------------------
$ffffffffff ATI VGA BIOS information
$0a00000000 Title : GV-RX385512H_F1
$0a00000001 Date/time : 11/14/07 04:04
$0a00000002 Core clock : 670.000MHz
$0a00000003 Memory clock : 700.000MHz
$0a00000004 Reference clock : 27.000MHz
$0a00030000 PowerPlay state 0 : 669MHz/829MHz/1.21V/boot
$0a00030100 Performance level 1 : 669MHz/829MHz/1.21V
$0a00030200 Performance level 2 : 669MHz/829MHz/1.21V
$0a00030001 PowerPlay state 1 : 300MHz/700MHz/1.01V/Overdrive
$0a00030101 Performance level 1 : 300MHz/700MHz/1.01V
$0a00030201 Performance level 2 : 669MHz/700MHz/1.21V
$0a00030002 PowerPlay state 2 : 300MHz/700MHz/1.21V
$0a00030102 Performance level 1 : 300MHz/700MHz/1.21V
$0a00030202 Performance level 2 : 669MHz/700MHz/1.21V
$0a00030003 PowerPlay state 3 : 669MHz/700MHz/1.21V/UVD
$0a00030103 Performance level 1 : 669MHz/700MHz/1.21V
$0a00030203 Performance level 2 : 669MHz/700MHz/1.21V
$0a00000008 Memory type : DDR3
Is it possible for me to go for 900 core and 1000 mem. If someone is willing to mod my bios?
my bios version is: .068
But now the problem for me is to save my current bios. So far i am not able to do that. If i make a MS-DOS disk, i can access it in windows, but it wont boot up from restart. 1st boot device is put to Floppy. But it says Floppy Disk fail "40". So far i am not able to make bootable USB thumbdrive as well :(
@Viilutaja
just save your bios with Atiwinflash, open AWF hit the save button, choose a name and you are set.
Ok, thanx, i got it saved. Can anyone mod this bios for higher 3D clock voltage?
I also looked what memorys are on the PCB. There was:
Hynix
HY5RS123235B
FP-14 731A
VTFF1400G1
For me its really hard to read out what kind of ns those memory modules have :(
@eva2000, glad to hear that your card also benefits nicely from my bios. when editing, just edit the grouped-together parts, not all 6. After editing something, the checksum will need to be corrected again before flashing for better compatibility ( I think)..
@zuelber, maybe it's because HIS bios cannot change voltages with other brands? What's your brand?
in Crossfire i revert to stock bioses without voltage bios mod.. so stock bios no mods CF clocks are @783-796Mhz GPU for both cards with mem at 1098mhz all done via ATI CCC overdrive.
Oh so you only edited 5 out of the 6 entries for for 3d clocks.. wonder if that makes a difference as i have yet to be able to make myself a 810/1000 bios that works heh
How do you get so high memory clocks? Mine goes only to 880 with ATI Auto-tune. And in rivatuner the 900 seems to be as far as she goes :(
Does this Hynix memory suck.
And anybody? Can somebody help me to mod my bios, even if someone would help me to find those hex values what to change, i am up to do those myself.
no idea.. both my cards probably have samsung memory with rivatuner in single card without ATI CCC can clock memory to 1152mhz without artifacts and 1172mhz with very very minor artifacts.
I think I reached my limits. Anything higher crashes 3DMark06 halfway through the first test.
http://img264.imageshack.us/img264/7...rk11515hh1.jpg
I have a Powercolor Xtreme 512mb but the retail bios was a HIS 067, that's why i tried your bios. With retail bios i can't overclock 1Mhz even with CCC. Is atitools accurate for artifacts scan? Cause that's how i found a 763 mhz core limit and i didn't tried anything higher than that, should i?
I have no idea how you guys even get atitool to work. The only util I can use is riva.
I can do about 1100-1110mhz mem with this qimonda. Some say it dies at those speeds tho so I generally just run it at 1000-1030.
GenTarkin
385/ 925
thx a lot
