hey guys, first post!
I love this board. but the only problem i've seen and wonder if anyone else has had this problem or knows how to fix it.. my cpu fan (stock heat sink btw) seems to stay at 780rpm or 840rpm in guru.
I've tried everything i can think of disabling FanEQ, then enable it, change it to PWM then back, i've set all the lows to 11.5 or 95% to try and make it run fast.. and i've tried everything in Guru's options... when i First got the system running, the fan would run close to 2k on rpms cause i changed the volts for low to 11.5v. Then one time i hit F8 in the bios to "oc on the fly" well my bios froze and since then i've always had the low reading despite temps in the high 40's. Ive even tried uninstalling guru then installing again. but still the same stupid 780rpm reading
another thing.. i've currently running a e2180 at 3.2Ghz but i gotta set the voltage to like 1.5375 which shows up as 1.57 on the front of guru.. now it runs fine at 3.0Ghz with like 1.45v but won't boot till i up the voltage for 3.2Ghz.. my other voltage specs are:
ddr2 2.200
mch 1.30
ichio 1.55
cpu vtt 1.30
ich 1.10
bios is version 11.
ram is Gskill running at 1000mhz with 5-4-3-5 timings
see anything that i could do to help lower the cpu voltage? worlds different OCing this compaired to my p4 3.2Ghz :)
