Originally Posted by
N.I.C
No my friend has Gigabyte X48T-DQ6...Also i have an Asus Evolution, i've tested there all the other h/w, it worked perfectly... As you know if you have RE, the Leds must light up when the power is on etc, as Cheapseats said...None of the leds were lit up, except from ROG Logo on the center... Also, the LCD Poster did not respond on the switches, it just keep counting all the time, i couldn't see the TEMPS or VOLTS etc, and also no CPU_INT were shown by the poster, as should be... I've tried to power up the m/b with the 4pin connector on 12V, no luck... Also tried to open it without cpu or ram, in that case i am sure that the mobo should warn me in somehow that there is no CPU or RAM on it... Nothing happened, no Leds were lit :shakes:.. I've tried the same think on Evo, and a blue led near s775 and near dimm slots, were on and blinking :D... The last thing i've done, was to leave the m/b out of the power and without the battary for a night... No luck, so i've tried anything, unfortunatelly i don't have right now a multimeter to check the real volts on m/b, anyway i think that it's dead :shakes:, tommorow im going to return it :up:i hope it wont take a lot..
