I think you are right. :(
If it is true that new i5 processors will have same performances than i7, clock by clock, counting that the MB for i5 will be at least 100 US$ less in price, I feel that in fall our MB will be jurassic.
So is it worth to buy asus rampage 2 extreme right now ?
I want make upgrade of my old rig to new rig but i don't know which mobo. r2e is my favorite ;)
Someone that claimed to be an ASUS Technical Marketing Specialist rep. on [H] say the EOL rumor is false, but i dont know what to belive.
However i would not buy this board without test it to make sure the coldbootissue are solved or present with a perticular setup. That is a anoying feature(among other things) my board has with my specific setup with any BIOS or PSU and make me turn to another brand and board before that limited edition one is out of stock from my prefered retailer.
If you want a B3 then EVGA X58 LE is said to be a B3 revison but that board has its limitations as the name of it say..
I heard that this problem with coldboot is over. And now everything works fine on asus rampage 2 extreme. About evga ... yes she have b3 chipset but how about OC etc. - for now that is one big "mistery" :)
I still see no reason what-so-ever to use a screwdriver on the northbridge heatsink. As all you have to do is use the pci-e sound card in the last pci-e slot at the bottom of the board. Because it still will only do 8x so i rather have a working sound card in that slot then a 8x card being choked to 8x.
So you ruined a heatsink for no reason at all....lol
Good Day
Somebody from a german forum went mad when he got his RIIE back from rma and the third ram slot still has not been fixed.
( http://www.hardwareluxx.de/community...postcount=2122 )
Here is the result:
http://www.abload.de/thumb/13062009508lutm.jpg
http://www.abload.de/thumb/13062009509hpoz.jpg
:wierd:
What you think - Asus will take it for RMA again ?:rofl:
oh dear, he must have money to waste.
I just got the same soundcard but my gfx is watercooled and the block dosent cover the pcie slot that is over the card,
can I use the soundcard in that one? then I dont have the bend the fins on the NB heatsink.
I tried installing the orginal soundcard there that comes with the card but that resulted in no sound why?(the drivers dident find the card either),
Is it only the black slot that can handle soundcards or what?
Well as you can see http://img31.imageshack.us/img31/203...rafia0179u.jpg Titanium card in the last slot could affect my air-flow to VGA cards.... so that's the main reason why i damaged that heatsink.
No PCIe 100Mhz and i have http://valid.canardpc.com/show_oc.php?id=585845:up:
any new bios release I have missed?
With PCIe at 115 I did 229 BCLK. QPI at 1.5v
http://valid.canardpc.com/show_oc.php?id=586040
I need help. I can't seem to enable Turbo Mode on my R2E. What are the settings I should set to make it appear in the BIOS? Darn, I'm only at 20x multi all the time :(
Anyone's got the latest R2E with the B3 chipset yet?
