Originally Posted by tribal0710
Babsy ... leave all that Asus AI :banana::banana::banana::banana: ... uninstall everything except Asus Probe and Asus Update ! Then go to bios and do this:
1."Cpu config" tab - Disable everything - cpu multi lock @ 9x
2. Free jumper set. tab - 400FSB/800ram (assure ure in 1:1 ratio) / 1.45Vcore , 1.55VNB , 1.6VSB , 1.057VICH , 2.1-2.2Vdimm, Disable spread spectrum, Lock PCI-e @ 110 , Lock PCI-clk @ 33.33
3.Also its recommended that u disable all fan controllers in bios
If it doesnt post or it aint stable leave everything as above just change cpu multi to 8x , put 450FSB/900ram , 2.2-2.3Vdimm(u should also set manually ram timings at 5-5-5-15) and see if it works. GL
