Big thx :D
Big thx :D
my turn. nothing spectacular, i cant afford a city of thermalright
http://i37.photobucket.com/albums/e9...d/DSCF2764.jpg
nice ! just wanna know what happen to the 2 92mm fans ?
master of thermalright / mr thermalright with an arctic cooling gpu cooler... what an insult !
Ar3s, thanks, took them out cause i dont have airflow in that direction and i get good temps without them. i'll be getting some 92mm filters to cover up the holes
64dragon, nice wire management :up:
if that is a silverstone FN121 on the top with some transparent fan obviously the FN121 will push almost no air out and start to sound terrible after sometime cause of its sleeve bearing.
latest encarnation of my rig,
when it was watercooled.
http://i7.photobucket.com/albums/y26...2/PICT0625.jpg
due to a leak i decided to revert back to air. so out with the water in with the air :)
http://i7.photobucket.com/albums/y26.../PICT06652.jpg
Boo! I love my water cooled A05, but to each his own I guess. I'm guessing the screen you have in the first drive bad doesn't go back into the drive bay very far so that you could fit the 3x radiator? I went the other rout and but the rad at the bottom of the case, but I am looking into putting a 2x rad on top for a GPU loop.
my new shiny case:
http://i7.photobucket.com/albums/y28...e/DSCF1943.jpg
http://i7.photobucket.com/albums/y28...e/DSCF1944.jpg
http://i7.photobucket.com/albums/y28...e/DSCF1947.jpg
i like having a window now, its pretty inside
Sc4mpi What happened with the leak dude?
Well the ddc top seemed to have a hairline crack which wasnt noticable when installing it. so as the water heated up the crack expanded and water started to drip onto the psu. which i only noticed when the psu when bang a week ago :shocked:. so on closer inspection you could only see it leaking if you took the side panel off maby once you have played a game for a hour or two. so i decided that i was lucky it dint take the rest of the rig with it and choose to go bk to air for the safe factor :> (hense the new psu :P)
My new air cooled build. A few things are still to do :)
http://www.abload.de/img/img_4214aw2.jpg
http://www.abload.de/img/img_4215zxh.jpg
http://www.abload.de/img/img_4217izp.jpg
http://www.abload.de/img/img_4218348.jpg
Sc4mpi ouch, sorry to hear that! Ill be leaving the air cooling world Jan / Feb so i hope i have better luck!
Steffen Nice Rig, love the cable management. Ill be using the older bro of that case :D PC-A71 :D
Tommy_Hewitt and Steffen
Very nice cable management
HR-03 + will come for the GTX once i can find the damn thing in my country. I also added a Scythe Kama bay below the dvdrw drive (not in pics) and have another Scythe sflex in front of the top HDD compartment.
Click on pics for bigger version.
http://ocidb.com/albums/userpics/101...l_IMG_2556.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2559.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2560.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2564.jpg
Hey Origin_Unknown have you got any pics of your rig?
your specs/sig looks like it's one extreme air cooler :)
A little bit updated :rolleyes:
http://www.abload.de/img/img_4242mvq.jpg
http://www.abload.de/img/img_4245731.jpg
very very sexy rigs here guys :clap:
some pics of mine
http://www.abload.de/img/img_6390dgh.jpg
http://www.abload.de/img/img_6394lw3.jpg
http://www.abload.de/img/img_63950al.jpg
I am a big fan of the old Coolermaster ATC Cases :)
Ghetto modded my GTX :D With stock cooling and stock clocks i used to get 61C idle and 95C :eek: :eek: after 10 minutes of FUR test.
Click on pics for bigger version...
http://ocidb.com/albums/userpics/101...l_IMG_2635.jpg
http://ocidb.com/albums/userpics/101..._IMG_2636.jpg]
http://ocidb.com/albums/userpics/101...l_IMG_2637.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2639.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2640.jpg
http://ocidb.com/albums/userpics/101...l_IMG_2641.jpg
FULL LOAD - FUR test for 15minutes + prime95 for 4minutes
http://ocidb.com/albums/userpics/101...d_cpu_load.JPG
IDLE - 5 minutes after i stopped FUR test and prime95
http://ocidb.com/albums/userpics/101..._afterload.jpg
Temps will never get this high in 3dmark or any game so i'm really happy about it :up:
