at 2000MhZ 7-8-7-20 1T, with 920D0, I put 1.50v in vqpi (in idle 1.46v and ~1.43v in load) to be stable h24 7/7
the R2E varies greatly on tension...
To overclock is better to let the SpeedStep enabled or disabled?
So none have any idea on my problem? isent it supposed to give a taskbar icon
well tomorrow i should finally get my CPU and make the rig real..... seems like i should be ok to just flash the bios 1406 right? The board has certainly an old one without 975EE support....also i'm gonna use G19 and notes says that support for this keyboard is improved in 1406...
Thats not Right :shocked: Thanks for my Friend mayk-freak
http://www.hardwareluxx.de/community...postcount=1902
I can access it here:
ftp://ftp.asus.com.tw/pub/ASUS/mb/LG...treme-1406.zip
PS - I was also able to drop my vcore down a couple of notches....
Ok but not of the Homepage Asus Downloads :confused: http://support.asus.com/download/dow...Language=en-us
Its in the History but not do Download :confused:
Hello XS
I just got this mobo and installed and everythign runs fine except I have some problem with the soundcard. I installed the drivers and the sound works but I have atm maxed windows volume setting and maxed headset volume and it is sometimes not loud enough anyone haveing the same problem?, on my old Maximus boards I couldent even have my headset on 50% volume because that was to much. I also never got a icon for the soundcard on my taskbar(like the ATi icon but for audio) after I installed the drivers. Without the icon I can basicly only play with the windows settings shouldent this card have professional settings like my previous Maximus I and II had?, the soundcard looks the same to me. I tried reinstall the drivers without getting the taskbar icon so what am I doign wrong?. I downloaded the sound drivers from Asus site the only ones that is on there(7.5 mb). Anyone have any ideas what is wrong, anyone have any solution?
I am using Vista 64 if that might have something to do with it.
//Aqua
http://www.xtremesystems.org/forums/....php?p=3831763
Check this link, the drivers in it might be of more help. I would ask the guy that found them first to be sure.
Bios 1406 sounds good. Got to try that see how it overclocks. Anyone lap the i7 hear?
I was thinking about it, it made no difference when i did my E8600, so i would like to find what i will run this one at 24/7 and if the temps could be a lot better then it will get done too.
This guy did his:
http://www.xtremesystems.org/forums/...&postcount=280
I think this might help to a lot of people. It's X-Fi Titanium Fatality Pro sound card in first black Pci-e 1x slot. I also placed 280GTX card so you can see how it will look like in real.
Took me about 40 seconds with screwdriver help...
http://img268.imageshack.us/img268/1...grafia0174.jpg
http://img192.imageshack.us/img192/7...grafia0176.jpg
http://img268.imageshack.us/img268/5...grafia0177.jpg
I know it and I did re-enter them manually. ;)
Unfortunately till now I was not able to find a rock stable situation with RAM at 2000 MHz.
Anyway the issue after S3 suspension is still present: CAS is set at 4 when you awake from an S3 stand-by and the ICM memory area is still not writable so you can not set latencies, etc. with CPU-Tweaker.
So everighing fit very nice after all including Titanium card in 1st black slot... the board is AWESOME stable !!!!
http://img31.imageshack.us/img31/203...rafia0179u.jpg
Also core i7 LOVES WORLD OF WARCRAFT :))) G19 screen from overcrovded Dalaran. All graphic settings MAXED to the bone and all i have are 60 fps constant with no shuttering, no lags.... smooth play. What an upgrade from C2D
http://img31.imageshack.us/img31/4490/g19displejv.jpg
Guys i have question, how i can check this mobo in shop dose it have stepping b3 of chipset ?
It doesn't and probably won't ever come with b3 revision IOH. The word on the street is they have EOLed the RIIE and are *either going to focus on the P55/P57 with the ROG line or introduce a new X58 ROG board with the fall line-up refresh (along with P6X Premium).
*pure speculation on my part from here forward ;)
