Help, I am having bios issues when changing settings. When I change some settings in the bios and save and exit, the pc shuts off, then restarts by itself after a few seconds. Upon powering up, I get a constant beeping and message on monitor saying: you have not connected the power cable to your video card. Does this with one or two video cards installed. Hitting reset will give the same message. After switching off the power, I can restart again. But I get the overclocking failed message. Then press F1 and enter bios, select exit and discard changes, (my settings are still there), the pc boots and will always boot. And tested prime and occt stable. I'm only mildly oc'ing a G0 at 3.2. I don't know why I am getting the video power cable message. System is very stable. Power supply voltages are super stable. Runs very cool at these settings so heat is not an issue.
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
Ratio CMOS Setting : 9
FSB Frequency : 356
FSB Strap to North Bridge : Auto
PCI-E Frequency: 100
DRAM Frequency: DDR2-855
DRAM Command Rate : 2T
DRAM Timing Control: Manual
CAS# Latency :5
RAS# to CAS# Delay :5
RAS# Precharge :5
RAS# ActivateTime :12
RAS# to RAS# Delay :AUTO
Row Refresh Cycle Time :AUTO
Write Recovery Time :AUTO
Read to Precharge Time :AUTO
Read to Write Delay (S/D) :AUTO
Write to Read Delay (S) :AUTO
Write to Read Delay (D) :AUTO
Read to Read Delay (S) :AUTO
Read to Read Delay (D) :AUTO
Write to Write Delay (S) :AUTO
Write to Write Delay (D) :AUTO
DRAM Static Read Control: AUTO
Ai Clock Twister : AUTO
Transaction Booster : AUTO
CPU Voltage : AUTO
CPU PLL Voltage : AUTO
North Bridge Voltage : AUTO
DRAM Voltage : 1.98 (2.06 in Windows)
FSB Termination Voltage :AUTO
South Bridge Voltage : AUTO
CPU GTL Reference : AUTO
North Bridge GTL Reference : AUTO
DDR2 Channel A REF Voltage : Auto
DDR2 Channel B REF Voltage : Auto
DDR2 Controller REF Voltage : Auto
SB 1.5V Voltage : AUTO
NB LED Selection : FSBT Volt
SB LED Selection : SB 1.5 Volt
CPU LED Selection : PLL VOlt
Voltiminder LED : Enabled
Advanced CPU Configuration
Ratio CMOS Setting : 9.0
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
