a little info ;) is german but a nice pic :)
Link to the DFI x48
- elle -
Link to the DFI x48
- elle -
beautiful ! mine are excatly like that. im happy.
thanks for that .
Any one know how to enable boot selection menu during P.O.S.T without entering bios?.
The Noctua NH-U12P is 126mm wide plus the clips, which stick out another 4-5mm on each side. Also, the height of the bottom fin is 40mm from the base. As long as the lower part of the NB heatsink is less than 40mm from the top of the CPU (which I think it is), you should be OK to overlap it. Is yours the Armor or new Armor+? I had a Xaser VI (which is the same as the new Armor+) and I think you should be OK there.
BTW all - I figured out the audio problem I was having. Simple id10t error :cussing:
IDK how similar the layout of this board is to the P35-T2R, but that mobo is listed on the Noctua website as compatible with the NH-U12P.
eva2000 i'm @ 500fsb on 5:6 divider if i switch to 1:1 same voltages i cant boot into windows verry wierd
I heard that there is problem with regulation,true? And is there some kind of problems with this board? 85 pages is just too much to read...
Try using the search feature at the top of the page to narrow it down. For example, here is a search for "voltage" (only nine pages):
http://www.xtremesystems.org/forums/...archid=5368507
And one for "problem" (only 5 pages):
http://www.xtremesystems.org/forums/...archid=5368548
I just installed Noctua NH U12P - it fit perfect on this Mobo.
What is yours NB temp?Mine is 60 degree under stress - is it not too much?
OMG
I'm so sick of waiting.
First they say got DFI stock on february, then delay till mid of feb. Later on they told me the board will arrive on 29th Feb.
Now they telling me there's no stock arrive and maybe Mid of March can get. They can't give me the actual date, later wait till mid of march no stock also.
Might really go for Asus Maximus Formula.
i PM'd you, nles!
So I buy a premium board, a premium cpu, and then I have to mickey mouse it to work? Ridiculous if you ask me. Even with this silly work around, I can install Vista, but then it will freeze more often than not when doing a warm boot afterwards. Only cold boots seem to work ok.
Even with all of the available options in the bios for tweaking, I would have rather had a board that at least works as it should.......
