Lestat ... you should not make judgements so quickly. The new CoolerMaster eclipse is pretty good even against high-end watercooling ... air is definitely reaching a point where it can go on par with internal watercooling.
no its really not scythe... but anyway eagerly awaiting the next bios since I'm sort of stuck with my RAM at poor speeds atm :S
No key or mouse press will turn this thing on. I've tried enabling both keyboard and mouse usb support to no avail. It doesn't work for me. Does anyone use this feature succesfully on DS3?
Also, a buddy of mine's got no crackling w/ an X-Fi Fatal and BF2142. I've got the Xtrememusic. If it's XRAM, I'm gonna feel like a tard. :D
Crackling and popping has nothing to do with motherboard, its a bios settings on PCI latency issue that has plagued Creative cards for a long time. Its mostly prevalent on Nforce mobos, but more recently any chipset. I had it on my other motherboard, i fixed it completely just by changing PCI latency.
Are you an idiot? =) There's no way air can beat watercooling... Your "on par" is 15-20ºC away? :slapass:Quote:
Originally Posted by ScythedBlade
Yeah I still have that tool, I'll give it a shot.Quote:
Originally Posted by markopoleo
some of the new air coolers are great but one by coolermaster, hahah thats hilarious. coolermaster has never made a good hsf. ever...
the Scythe infinity is one of the few killer hsf's. and i mean when you actually mount a fan on it, not just using passive.
you wanna run 1.67v on air be my guest but your temps are astronimical. end of story,, you can claim all you want this and that but i know for a fact that at 1.67v on air or water, its suicide.
christ, @ 1.57v my cpu gets so hot i wont do it. only quick runs into windows.
you can not get around the truth, and that is 1.67v #1 will kill your cpu. #2 produces so much wattage on these cpu's that heat is insane. i n s a n e.
i guarentee that your load temps were into the 80's and 90's
only way it wasnt was if you have the mobo outside of the case in a VERY cool room, or by a window and its cold outside.
That's why I keep mine @ stock. It'll hit 3600 with a .1V increase, but load temps go 60C-65C instead of 50C for 3300.
http://www.virtual-hideout.net/revie...se/index.shtmlQuote:
Well it certainly looks cool. :fact:
Yea ... still decent enough ... (which is better though I forgot ... scythe mine or infinity?)
Here is the tool Lestat keeps talking about and not giving a link to http://www13.plala.or.jp/setfsb/Quote:
Originally Posted by msgclb
Lestat, you were killing me! ;)
i figured everyone knew about that program
sorry.
i was going to post a link for it but i totally spaced it off.
its the one at the bottom of the list. its for the ga965
should work on DS4 and DQ6 it works fine for the DS3
just be sure your voltages are set high enough to handle the new overclock you will be setting with this program.
Infinity. I have the Mine and I'm probably going to try a Tuniq Tower when they're back in stock. The Mine is a cheap, quiet solution but it's not that great of a cooler.Quote:
I'am still on Bios F3 , but is there already a bios witch you can give the cpu 1.65V ?
hey guys , im just going to add some comments about the cooling on air , I have the Tuniq tower and that thing works great my temps go from 37 up till 44 @ 1.56 full load running at 3.3 (E6600) , I ve try 1.6 but my setup wont go more tahn 3.4 and still keep 44-45 on full load, sooo when Gigabyte "release "the new bios that is suppost to have more Volts option for cpu im going to try more than 1.6 to see where i can go , see u al
And btw where can i download SetFSB965 please , need a link
Wow you lazy man :)Quote:
Originally Posted by Ajfina
Look 4 posts over yours and you'll discover this secret;)
damn IM TOTALLY BLIND , THANKS DUDE :)Quote:
Originally Posted by DStealth
And it would fit on my board...I wonder how it would do against some of the better coolers tho...Quote:
Originally Posted by Phosphate
And "for GA-965P Ultra Version 1.5a2" will work for the DS3 too?
Yeah I have no idea. I just think it "looks" cooler than most and by that I am refering to its unusual appearance more than anything else.Quote:
Originally Posted by Jodiuh
Swap in a nice 120mm fan and that Mine becomes a great cooler.Quote:
Originally Posted by aldamon
I already have and it's still far from being a great cooler. It doesn't have enough surface area to compete with the big boys.Quote:
Originally Posted by rob725
Obviously, "great" and far from it are subjective terms and I would agree that it does not rank up there with the best coolers (I'd like to get my hands on a tuniq tower myself), but it is doing a great job for my buddy, who wanted to save some money, and he runs both cores 100% 24/7 at 3.6ghz, with load temps around 50, crunching for the xs wcg team.
So no bios updates then?
its coming rich its coming.
today?!Quote:
Originally Posted by Lestat
