OCP mod is in this thread, page 33 post 825
maybe i wont need a fan on my machine
just finished my waterblock for my board
http://inlinethumb04.webshots.com/20...600x600Q85.jpg
still on my dead board... going to RMA next week once i get this block installed in my machine
this is the clearance for my video card. Just fits
http://inlinethumb11.webshots.com/44...600x600Q85.jpg
PowerColor HD5770 Eyefinity5 video card I'm going to use,
almost finished the block for that
http://inlinethumb37.webshots.com/39...600x600Q85.jpg
Hi there,
nice soldering work. Just on a side note, has anybody ever wondered why the chip in the bottom left corner of the board is being cooled by the heatpipe block?
It's a simple gigabyte rebranded JMicron JMB 0363 SATA/IDE controller...and needs no cooling at all. You can find those on many cheaper boards with much less fancy cooling...
:shrug:
You can use Speedfan to control fan speed for the CPU_Fan header, but I haven't found a way to use any of the other headers on the UD7 except at 100%.
To use Speedfan you'll have to disable SmartFan in the BIOS, forcing CPU_Fan to run at 100%, and then use Speedfan to control speeds. Speedfan allows you to control a fan dynamically based on a chosen temperature; I have one fan controlled this way by CPU temp.
Once you get Speedfan setup you can run it as a task at startup.
Yo man!:D
It looks like a graet work.:clap: Let us know how it is cooling your stuff.:shocked:
@Amurtigress,
I was always wondering why a JMicron JMB 0363 SATA/IDE controller needs this special cooling on this board. First I thought there must be some kind of mystery the way Gigabyte stresses this god damned chip but this board wonīt stress this controller more than any other boards. It is all pomposity isnīt it?
well I won't get a chance to install it for a couple weeks :(
I use my machine all week for work. so any changes i usually do on Saturday, so any screw ups i can revert it back in time on Sunday to work Monday.
next weekend I'm out of town so it won't happen till following weekend.
will also have to redo my ram block to change the outlet, so that it lines up with MB block inlet of by the PWM
http://inlinethumb48.webshots.com/45...600x600Q85.jpg
A bit off topic but I just figured out that going from 101MHz to 102MHz with PCI-e on rev1.0 of this board switched the two LAN ports from 1000Mbps to 100Mbps
Have you added some volts to your PCI-E ports ?
I'm running at 1.540v
I'm only running at 200bclk
my complete bios template below
I'm a lazy overclocker... found a template that worked and only did a few changes.Code:Advanced CPU Features:
CPU Clock Ratio .........................[21]
Intel(R) Turbo Boost Tech ...............[DISABLED]
CPU Cores Enabled .......................[All]
CPU Multi Threading .....................[ENABLED]
CPU Enhanced Halt (C1E) .................[ENABLED]
C3/C6/C7 State Support ..................[DISABLED]
CPU Thermal Monitor .....................[ENABLED]
CPU EIST Function .......................[ENABLED]
Bi-Directional PROCHOT ..................[ENABLED]
Virtualization Technology ...............[ENABLED]
Uncore & QPI Features:
QPI Clock Ratio..........................[36x]
QPI Link Speed ..........................[7.2GHz]
Uncore Clock Ration......................[17x]
Uncore Frequency ........................[3400MHz]
Isonchronous Frequency ..................[ENABLED]
Standard Clock Control:
Base Clock (BCLK) Control ...............[ENABLED]
BCLK Frequency (MHz) ....................[200]
PCI Express Frequency (MHz) .............[105]
Advanced Clock Control:
CPU Clock Drive .........................[700mV]
PCI Express Clock Drive .................[700mV]
CPU Clock Skew ..........................[0ps]
IOH Clock Skew ..........................[0ps]
Advanced DRAM Features:
Performance Enhance .....................[TURBO]
Extreme Memory Profile (X.M.P) ..........[DISABLED]
System Memory Multiplier (SPD) ..........[8.0]
Memory Frequency (Mhz)...................1600
DRAM Timing Selectable (SPD) ............[QUICK]
Channel A + B + C
Channel A Timing Settings:
##Channel A Standard Timing Control##
CAS Latency Time ........................[9]
tRCD ....................................[9]
tRP .....................................[9]
tRAS ....................................[24]
Command Rate (CMD).......................[1]
Channel Interleaving.....................[6]
Rank Interleaving........................[4]
Advanced Voltage Control:
Load Line Calibration ...................[LEVEL2]
CPU Vcore 1.20000v.......................[1.35000v]
QPI/VTT Voltage 1.175v ..................[1.355v]
CPU PLL 1.800v ..........................[1.840v]
PCIE 1.500v .............................[1.540]
QPI PLL 1.100v ..........................[1.220v]
ICH I/O 1.500v ..........................[1.500v]
IOH Core 1.100v .........................[1.140v]
DRAM
DRAM Voltage 1.500v .....................[1.600v]
DRAM Termination 0.750v..................[AUTO]
Ch-A Data VRef. 0.750v ..................[AUTO]
Ch-B Data VRef. 0.750v ..................[AUTO]
Ch-C Data VRef. 0.750v ..................[AUTO]
Ch-A Address VRef. 0.750v ...............[AUTO]
Ch-B Address VRef. 0.750v ...............[AUTO]
Ch-C Address VRef. 0.750v ...............[AUTO]
If I could find a template that would get me up to 4.5Ghz I'd take it...
I prefer to mod,,, hate the endless reboot cycle, change a setting reboot, test, change a setting reboot.
MadHacker, that is some cool looking WC "pun intended".
MadHacker, I havent tried this with power savings options enabled. If this is not stable can drop to 210bclk and use same settings for 4400mhz or 205 bclk for 4300mhz(adjust vcore as needed). I use these settings, and to go higher only thing I change is vcore, vtt and pcie freq. if needed (mem timings and freq will depend on your ram). This has worked on 4 bloomfield chips.
QPI Link Speed ..........................[7.2GHz] 7.74
Uncore Clock Ration......................[17x] 16x
Uncore Frequency ........................[3400MHz] 3440
BCLK Frequency (MHz) ....................[200] 215
PCI Express Frequency (MHz) .............[105] 103, if fails try 105.
CPU Clock Drive .........................[700mV] 800
PCI Express Clock Drive .................[700mV] 900
System Memory Multiplier (SPD) ..........[8.0] may have to use 6.0 if your ram is rated 1600mhz.
Channel A + B + C
Load Line Calibration ...................[LEVEL2] level 1
CPU Vcore 1.20000v.......................[1.35000v] 1.450-1.4625v ( vcore will depend on your chip)
QPI/VTT Voltage 1.175v ..................[1.355v] 1.335-1.355v
CPU PLL 1.800v ..........................[1.840v] 1.60v
PCIE 1.500v .............................[1.540] normal
QPI PLL 1.100v ..........................[1.220v] 1.16v
ICH I/O 1.500v ..........................[1.500v] normal
IOH Core 1.100v .........................[1.140v] 1.16v
DRAM
DRAM Voltage 1.500v .....................[1.600v] whatever ram spec is
DRAM Termination 0.750v..................[AUTO] normal
Ch-A Data VRef. 0.750v ..................[AUTO] normal
Ch-B Data VRef. 0.750v ..................[AUTO] normal
Ch-C Data VRef. 0.750v ..................[AUTO] normal
Ch-A Address VRef. 0.750v ...............[AUTO] normal
Ch-B Address VRef. 0.750v ...............[AUTO] normal
Ch-C Address VRef. 0.750v ...............[AUTO] normal
Thanks...
I'll compare the settings and see what is different.
I'll try it once I get the waterblock install on my MB.
last time I tried overclocking to 4.3Ghz I killed my board running linx.
so I bought another. used the dead board to build my full cover MB block
now to RMA it.
edit:I have 6 sticks of Corsair Dominator 1866 ram, watercooled, so without overclocking my ram i should be able to reach 233 bclk
^^ I have used 215bclk/4500mhz for around 8-9 months now, board is still running good.
If you did not set these to 700 your self you can not just change them to 800/900. Thats what they should be by default. If they are not that way you have to Load Optimized defaults. then manually reset your overclock settings.
102 pci-e should get you to 224-225 bclk as that is what is limited on the EX58 boards. X58a boards raised pci-e cap from 102.
this is my 24/7 settings 215 blck 8x mem 17x uncore 1.4vcore llc enabled 1.335 qpi/vtt
Hi all, OC Nub thank you very much....I have tried this settings and works fine....before that I was not able to reach 210 or 205.....great job! I didnt expect it worked with PLL 1.6. One answer...its better pcie 103 or 105....does it affect to temps or any other thing
Many thanks
clocking currently with my X5680 on the rev 1.0 UD7
it does not like 190bclk+
im guessing it is just because the cp isnt supported officially?
its currently sat at 182 X 22 @ 1.23v
memory at 1820 CL7-8-7-20 1T
I used the same settings but powersavings were disabled,not sure what vcore was set to in bios and HT was disabled for 4620mhz. http://www.xtremesystems.org/forums/...&postcount=767
@PLAY-911, if its stable at 103 leave it there, you may need to raise it for higher bclk.
got a few stability shots to share
will post bios profiles if anyone is interested...
4GHz
http://i75.photobucket.com/albums/i3...neill/run1.jpg
4.2GHz @ 1.3v :cool:
http://i75.photobucket.com/albums/i3...neill/run2.jpg
