heres my try at lowering some of my voltages.this is with 8GB of G.skill pc8800.
here are the settings in the bios.
here is a screenshot of it priming.Code:Robust Graphics Booster ...............: Auto
CPU Clock Ratio .......................: 8
CPU Frequency .........................: 4.0GHz (500X8)
Clock Chip Control
Standard Clock Control
CPU Host Clock Control.................: [Enabled]
CPU Host Frequency (Mhz) ..............: 500
PCI Express Frequency (Mhz) ...........: auto
C.I.A.2 ...............................: [Disabled]
Advanced Clock Control
CPU Clock Drive........................: Default (900mV)
PCI Express Clock Drive................: Default (800mV)
CPU Clock Skew (ps)....................: 0ps
MCH Clock Skew (ps)....................: 50ps
DRAM Performance Control
Performance Enhance....................:Turbo
Extreme Memory Profile (X.M.P.)........: Disabled
(G)MCH Frequency Latch.................: 400
System Memory Multiplier ..............: 2.00D
Memory Frequency (Mhz) ................: 1000MHz
Standard Timing Control
CAS Latency Time.......................: 5
tRCD ..................................: 5
tRP'...................................: 5
tRAS...................................: 15
55
Advanced Timing Control. Performance level set to 9 (everything else untouched)
Motherboard Voltage Control
CPU
Load-Line Calibration..................: [Enabled]
CPU Vcore..............................: 1.368v
CPU Termination........................: 1.34v
CPU PLL................................: 1.570v
CPU Reference..........................:0.861
MCH/ICH
MCH Core...............................: 1.36v
Reference..............................:0.876
MCH/DRAM Ref...........................: Normal
ICH I/O................................: Normal
ICH Core...............................: Normal
DRAM
DRAM Voltage...........................: 1.90
DRAM Termination ......................: Normal
Channel A Reference....................: Normal
Channel B Reference ...................: Normal
http://i40.tinypic.com/w7yn9j.jpg
