Originally Posted by
CryptiK
@ GeorgeVasil - 4500 @ 1.288 is fantastic, nice chip you have there.
They are high chipset temps, especially for water. Have you placed washers behind the NB mounting screws? I just did that and the extra mounting pressure helped reduce the temps a few degrees. The chipset cooling design of these boards really leaves a lot to be desired.
When you use CPU clock skew, did you also use NB clock skew in conjunction with it? I found setting them the same (eg 300ps on both the cpu & NB) can improve stability in Orthos, but not in Linpack.
@ Rocks - yes linpack gets the cpu the hottest, but remember normal usage load temps wont ever approach those temps.
