And you wonder why I rarely post on here any more ;) think who I am dealing with, think what they would do if i disclosed everything I know...sometimes you guys live in a strange world where you forget everything is covered by embargo and NDA.
You guys do a good job, you would do better diverting some attention to testing Oroms for stability...there must be bios modders here who can inject the files...see what you find, I have end users doing this now with marked differences in stability.
Don't think the host controller/motherboards always work correctly...they never do, check the release notes with the oroms and RST..check the errata for the chipsets and make sure you are not fighting known bugs.
All I want now is for all motherboard manufacturers to get on the newest and most stable Orom, then I can get FW build that suits and works well with that Orom...and we all move forward. As it is now, im fighting boards on 10.1, 10.3, 10.5 some on 10.6 and a few which generally give no issues on 11.
Regards some of the things you guys have found....we watch what you are doing and like i said you do good work...just don't feel I have to break NDA to justify what I say..I do not and will not.
never going to happen, you guys think the bsod issue is MASSIVE...its not, we have been selling 100k+ drives a month and no where near 100K of them show this issue or come back on RMA. My POLL thread has 160 people tops posting and near 50% of them are having a more positive experience...There is an issue for some and we are working on it..and yes making progress.Quote:
my view SF2xx products should be recalled.
I run an MSI 890FXA GD80 here with a 1090T at 3.8, ram at 1200 6-5-5-18 (8GB 1T) memory controller at 2800mhz, main OS drive Revo 480 x2, secondary test OS drives vtx3, vtx3maxIO, Agy3, solid3, Revo3 x2, Revo3...you name it I have run it...and for day to day I have no tweaks, the machine hybrid sleeps (even with the old revo's) and with the single drives I test Hibernation also..and I have never seen an issue except 2 drives disconnecting which I cured with a reg hack to force the sata ports to Internal mode only...so just like Ao1 I run for hours and hours and never see issues....i have not seen what the end users call a BSOD issue on any of the drives I have here and I have 20+ sata3 drives to hand. I tested these drives on Asus p67, Asrok Z68, MSI Z68 etc etc....never seen an issue.
It baffles me, i hoped it was just the drive as then I knew we could fix it...now im thinking its connected to something else that I have no control over.
So here is the challenge guys, join in the search, test the crap out of all the Oroms, all the drivers, all the boards, all the CPU's and all the drives you can...see if you can come up with what causes the boards to disconnect the drives, we can share notes ;) Just don't ask me for what I know to date...as you guessed it...I can not tell ;)
