Use the multi 19 and bump up the blck to 210, or use multi 20 and bump up the blck to 200, see which one works better.
Anyone else on this 1403 bios ? I seem to be able to run lower volts on the CPU then before to keep her stable... till now I needed 1.28ish set in the bios. It's still priming at 1.275 ( I urgently need back my DMM to verify the correct volts ) Maybe this bios overvolts even more than the older generation...
Anyone an idea or can anyone verify with his DMM...
Maybe that's it, I started to use this board again and I was coming from 11series bios... I needed 1.28ish Vcore set then to get prime stability, anything lower would have freezed in minutes. Now with 1403 I can run sub 1.27ish volts. Really puzzled...
Thx for the input, much appreciated
hi guys, i just moved to Windows 7 RC1 x64..the Xi-Fi Drivers for windows vista x64 keep giving me an error saying that it cannot detect the necessary hardware when i click on the audio console...4
any idea what might be the problem? i have all the latest drivers installed. thanks in advance (:
Where are you guys getting the 1403 bios from? I only see 1306 on the website.
not sure ever since i changed CPU to D0 and updated BIOS from 0903 to 1306
System POST with MASSIVE Lag! updated to 1403 beta and still the same...i have to wait ages for the system to POST...Any advice?
thanks in advance
Oh right :) lol.
Thanks BabyFace, Yeah i did notice that the splash screen takes longer to load and it became bad to worst after a few weeks the splash screen is taking longer and longer, i have gone back to 1206 and seems to be some improvement in terms of waiting time...
Thanks for the recommendation! Enermax arrived yesterday and I'm loving it, or actually my GTX 280 is. Starts from a cold boot every time. No more restarting/blank screens... now only the time will tell how long it will last - i do have high hopes though :) And now that I'm sure it was the PSU that failed i can get a replacement for future use.. and perhaps a D0 which is like an itch lately :D
Where's my share? HHehee...glad it works great for ya. It'll last a long time, but Enermax doesn't provide lifetime warranty on their PSUs, which is one of the reasons why I went with Prudent Way instead. They provide lifetime warranty on their PSUs, which is the first.
I using everest to read my NB/SB temps, it is reporting 48/46c my ambient temp is around 28c.
I did replace the ASUS TIM with some OCZ freeze and Sekisui tape.
I wondered what everyone else is getting with theirs?
pardon me but what is TIM ?:)
