I would say, but this dfi board is so screwy! I am not sure what volts I'm actually, I have a multimeter, but don't know where I can check the line from.
my burn in process?Quote:
so can you explain teh burn in process a little to me?
Find the max fsb where you might get 2 errors or so per pass or less..and just let the sticks keep working with memtest all day and part of the night..
You don't want alot of errors..because that would defeat the purpose of the burn in.
At night I turn the computer off...next morning ..I try that fsb to see if its stable or not..if not..I will try to burn it in again that day...just keep repeating till it takes and then go up another level on Fsb..or if it never takes...just give up and say..ok I can do X fsb..because burning isn't working.
Then around 2 weeks later..check that erroring fsb..and see if it now works...Sometimes it does...sometimes it doesn't
bad news for me... i believe i got a DOA stick from newegg... :(
will have to RMA it unless i was a moron and didnt stick it all the way in the slot (which i know i did correctly...)
it would boot with both sticks, but when i tried to install windows, it would create memory errors... at stock speeds and timings.
TRANS am ...You using
Cpc on or off?
Tell us your settings for memory so we know what your using..
Thanks bro.....
next week its time for an neo2 .. no way for nf4 ... to expensive .. and no need for PCIe
friend has a problem :
Well today I got my hands on this babies and i'm a bit dissipointed. I can only do 240 at 2.5 - 4 - 4 -8 with 3.3V on dimm. I bought it from a guy who said he could do 240 2-2-2-5 at the same voltage. But he's an AMD guru therefor used different mobo as me. That's why i've opened another thread in here.
my settings:
CAS: 2.5
RAS precharge: 4
RAS TO CAS: 4
Precharge delay: 8
burst lenght: 8
memory acceleration: enable
Idle timer: INF
refresh rate: 64uSec
Mobo: Asus p4p800-e dlx
CPU: P4 2.6C
TwinMos AA4T, 44D
PSU: chieftec 420W
Tried both in single or dual mode, each stick seperatly.
What else to try?
Before this ram I had corsair 3200LL in who could do 250 2-2-2-5 in single mode with no problems, but only 240 in dual.
Originally Posted by trans am
DFI NF4 rocks for me ...
my UTT can do 259 memtest#5 stable at 3.3v @ 2-2-5-2-8-15-2-2-1-1 with idle timer @ 16clocks
bad news is i can't go any more higher because 1 of the sticks is crap while the other can do for sure 270 @ 3.4.
(those UTT are the ones i had since the begining of the thread, and those that hipro5 tested the 2nd day i got them, i love this board)
i should have bought 2 pairs to choice the 2 best of each one too... (tictac slapping smile)
TEDY , i haven't seen any P4 bench with UTT (that i remember)... that would explain something... :confused:
Originally Posted by TEDY
tedy im not familiar with intel but you should keep CPC and PAT off to run UTT
What's the point in disabling CPC, does it have the same massive performance drop as on AMD platforms?
hipro5 can tell but if i recall correct he set it to off(or else PC wouldn't post) when we where testing in his AS8Quote:
Originally Posted by Rabbi_NZ
Just recieved 2x256 SP from newegg.
AA4T
TMD7608F8E44D
05034 DATE
KO-6633 PCB
Looks like you guys are looking for the 512's now. So just an update if anyone is still looking for the 256's.
so are the none speed premiums showing up as utt also now? Im ordering a gig of some sort tonight so i might chance it with those. I just need a gig, im not going after the fsb here but if I get it then Im in luck....
good luck shroomy,Quote:
Originally Posted by Shroomalistic
we'll have to catch up on msn sometime soon to talk sheeet bout your 2x256 kit... almost caught you online last night i think.
The first UTT to show up were non speed prems ... :D check post#1
my hours are bad right now, working 5am to 2pm but the job site is an hour away so I have to leave before 4am so I wake up at about 2:30am. We are working in a no noise after 8am skyrise in irvine. it sucks, my job consists of being loud. Hopefully i will catch up with you this weekend
i think i got 2 crap sticks...
finally got to test them... er... one of them... one was just plain DOA...
the other wouldnt boot 200mhz 2-2-2-5 1T at 2.85v. and at stock everything, i got a BSOD... that MIGHT have been something else... but its not looking good for my sticks...
i think i may just return this stuff and get something else...
it takes at least 3.1 to get 2-2-2 out of these mem.
otherwise stick with 2.5-3-3
and cpc off does not kill performance on Intel like it does on amd, its much more minor, shut it off.
actually it will do 2-3-3-X fine at stock voltage and speed
with clockgen... my one non-DOA stick will NOT do 2-3-3-8 220mhz... at 3v. got a BSOD.
i also got a BSOD at stock speeds/timings/voltage once... so i think this stuff is going back. not sure yet wether i sould get replacement sticks, or get something else... :(
Originally Posted by bobmanfoo
which is not 2-2-2
:p:
Thats sweet to hear it was the board....its def a pain to match up sticksQuote:
I have one that did 255 the other did 253
Next day the one that did 253 did 254
Following day it did 255
Weakest chain in the link.. After the mods are done on my board by CaTalyst.X
We will see what they can do at 3.5 or so..I think Ill be too scared to go above that..
wow already 2K posts in this thread.
when these get back in stock at newegg, what chances are that they will be utt +BP pcb.
i heard in this thread that week 48 of speed premium will be 100% utt +BP PCB. am i mistaken?
Hey all!
Im a long time reader here and first time poster.
Ive been following this thread as well as the one from Eoc for quite awhile.
Seems to me that newegg is the only place selling them and the fact that they are literally sold out in a matter of minutes seems to amaze me.
The Eta is still 2-10 and I am anxiously awaiting their availability. I really want this ram pretty bad to replace my PdP Patriot EP Pc3200 ram.
Would it be stupid to just setlle for the TmIII instead of waiting for the Tmsp?
Also since the 256mb sticks are readily available [last time i check at least] should i just get 2 of those?
If i got 3 sticks i would lose dual channel, but i'd be getting a higher Fsb.
I have contacted [Alice] at TwinMos asking for another place to buy from. She says newegg is the only place that carries them. For now at least. She is going to Email me to see if i can order directly from the factory.
Keep posting! I love reading about this ram. Just makes me want it more and more!
Are u serious? Newegg is the only company selling them?Quote:
Let us know what happens
Buy single stics of TMII and check each one out..TMII is what im guessing The thread starter is saying he had? I nver could figure out which ones he was refering too..just said the cheap ones...LolQuote:
I bought a dual pack..one did 261 fsb..other did 240 with some errors at 3.3 v
That was TMII Modules
