Originally Posted by Lestat
yeah the AMD comment was just a passing thought.
and update ? hhmm guess i better look for that button lol. yup it works. Thanks!
the download page only offers 0.1 Build 496 too bad the northbridge temps dont work but you always get those temp readings when there is a sensor reader there but no sensor...
sort of like mobo's that have a 3rd or 4th system fan plug but no way to control the fan. It will show whacky fan speeds.
Would you ahve a theory why Prime fails totally at the speeds im at but everything else, benchmarks and games and such work just fine without a single reboot or lock up ? Is prime just that more discreet on the cpu ? where as those other things arent ?
For me a huge test of my memory atleast is Newsleecher. If my ram and sometimes cpu are pushed to far it will download items and they will be checked as bad. but the minute i lower my clocks and redownlaod them they check as good. The program is very ram intensive using anywhere from 100-500+ megs of ram.. and since it is handling and converting binaries... well.... you can see how ram that is pushed to hard might cause bad headers or articles when they really arent bad. (just like memory errors in memtest)
